cabltv1 Posted January 29, 2009 Posted January 29, 2009 Please help! I need a lisp routine that does the following... 1) Select a block. 2) Get the information from 2 seperate TAGs in the block First TAG: NODE_ID Second TAG: DEVICE-TYPE_ID 3) I then need the two TAGs above to be combined with a dash (-) in between. Example: First TAG: NODE_ID = 1256 Second TAG: DEVICE-TYPE_ID = C5B3 Final = 1256-C5B3 4) I then need a "pause" to select several different blocks and update the following TAG... TAG: ACTIVE with the combined results.. TAG: ACTIVE = 1256-C5B3 Any help would be greatly appreciated. Quote
fixo Posted January 29, 2009 Posted January 29, 2009 Try this one ;; cca.lsp (defun C:CCA (/ attent atttag attval elist en head pt ss tail) (setq osm (getvar "osmode")) (setvar "osmode" 513) (setq pt (getpoint "\n *** Specify point on the source block ***")) (setq ss (ssget pt (list (cons 0 "INSERT") (cons 66 1)))) (sssetfirst nil ss) (if ss (progn (setq en (ssname ss 0)) (setq elist (entget en)) (while (= (cdr (assoc 0 (setq elist (entget (entnext (setq attent (cdr (assoc -1 elist)))))))) "ATTRIB") (setq atttag (cdr (assoc 2 elist))) (setq attval (cdr (assoc 1 elist))) (cond ((eq "NODE_ID" atttag) (setq head (cdr (assoc 1 elist)))) ((eq "DEVICE-TYPE_ID" atttag) (setq tail (cdr (assoc 1 elist)))) (T nil) ) (ssdel en ss) ) ) (princ "\n 0 blocks selected") ) (sssetfirst nil nil) (setq ss nil) (prompt "\n *** Select all target blocks you need to update ***") (setq ss (ssget (list (cons 0 "INSERT") (cons 66 1)))) (sssetfirst nil ss) (if (and head tail ss) (progn (while (setq en (ssname ss 0)) (setq elist (entget en)) (while (= (cdr (assoc 0 (setq elist (entget (entnext (setq attent (cdr (assoc -1 elist)))))))) "ATTRIB") (setq atttag (cdr (assoc 2 elist))) (if (eq "ACTIVE" atttag) (progn (entmod (subst (cons 1 (strcat head "-" tail)) (assoc 1 elist) elist)) (entupd en) ) ) (ssdel en ss) ) ) (sssetfirst nil nil) ) (princ "\n 0 blocks selected") ) (setvar "osmode" osm) (princ) ) (princ " *** Start command wit CCA ***") (princ) ~'J'~ Quote
cabltv1 Posted January 29, 2009 Author Posted January 29, 2009 Fixo, Thanks for your quick reply. I tried the routine and the first half works but the second part doesn't. I select the source block then select blocks that need the update and the following happens.... First TAG: NODE_ID (This does update the destination block/TAG:Active [including the dash]). The second source block TAG: DEVICE-TYPE_ID (is missing in destination block/TAG:Active [including the dash]). Example: Source Block: First TAG: NODE_ID = 1256 Second TAG: DEVICE-TYPE_ID = C5B3 ============================== After update... Destination block: TAG: ACTIVE = "1256-" The "C5B3" is missing at the end in destination block. Quote
Lee Mac Posted January 29, 2009 Posted January 29, 2009 Try this: (defun c:tagupd (/ bEnt aEnt aEntLst aNode aType nAtt ss entLst dAtt dAttLst) (vl-load-com) (if (and (setq bEnt (car (entsel "\nSelect Block to Retrieve Tag Values > "))) (= "INSERT" (cdr (assoc 0 (entget bEnt)))) (= 1 (cdr (assoc 66 (entget bEnt))))) (progn (setq aEnt (entnext bEnt)) (while (not (eq "SEQEND" (cdr (assoc 0 (setq aEntLst (entget aEnt)))))) (cond ((= "NODE_ID" (cdr (assoc 2 aEntLst))) (setq aNode (cdr (assoc 1 aEntLst)))) ((= "DEVICE-TYPE_ID" (cdr (assoc 2 aEntLst))) (setq aType (cdr (assoc 1 aEntLst))))) (setq aEnt (entnext aEnt))) (setq nAtt (strcat aNode (chr 45) aType)) (if (setq ss (ssget (list (cons 0 "INSERT") (cons 66 1) (if (getvar "CTAB") (cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE"))))))) (progn (setq entLst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entLst (setq dAtt (entnext ent)) (while (not (eq "SEQEND" (cdr (assoc 0 (setq dAttLst (entget dAtt)))))) (if (= "ACTIVE" (cdr (assoc 2 dAttLst))) (setq dAttLst (subst (cons 1 nAtt) (assoc 1 dAttLst) dAttLst)) (entmod dAttLst)) (setq dAtt (entnext dAtt))))) (princ "\n<!> No Destination Blocks Selected <!>"))) (princ "\n<!> No Attributed Block Selected <!>")) (command "_regenall") (princ)) Quote
Lee Mac Posted January 29, 2009 Posted January 29, 2009 Sorry, 1 thing missed: (defun c:tagupd (/ bEnt aEnt aEntLst aNode aType nAtt ss entLst dAtt dAttLst) (vl-load-com) (if (and (setq bEnt (car (entsel "\nSelect Block to Retrieve Tag Values > "))) (= "INSERT" (cdr (assoc 0 (entget bEnt)))) (= 1 (cdr (assoc 66 (entget bEnt))))) (progn (setq aEnt (entnext bEnt)) (while (not (eq "SEQEND" (cdr (assoc 0 (setq aEntLst (entget aEnt)))))) (cond ((= "NODE_ID" (cdr (assoc 2 aEntLst))) (setq aNode (cdr (assoc 1 aEntLst)))) ((= "DEVICE-TYPE_ID" (cdr (assoc 2 aEntLst))) (setq aType (cdr (assoc 1 aEntLst))))) (setq aEnt (entnext aEnt))) (setq nAtt (strcat aNode (chr 45) aType)) (if (setq ss (ssget (list (cons 0 "INSERT") (cons 66 1) (if (getvar "CTAB") (cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE"))))))) (progn (setq entLst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))) (foreach ent entLst (setq dAtt (entnext ent)) (while (not (eq "SEQEND" (cdr (assoc 0 (setq dAttLst (entget dAtt)))))) (if (= "ACTIVE" (cdr (assoc 2 dAttLst))) (progn (setq dAttLst (subst (cons 1 nAtt) (assoc 1 dAttLst) dAttLst)) (entmod dAttLst))) (setq dAtt (entnext dAtt))))) (princ "\n<!> No Destination Blocks Selected <!>"))) (princ "\n<!> No Attributed Block Selected <!>")) (command "_regenall") (princ)) Quote
cabltv1 Posted January 29, 2009 Author Posted January 29, 2009 Lee, Works perfectly! Thank you very much. You saved me a lot of time trying to figure this out on my own. Quote
Lee Mac Posted January 29, 2009 Posted January 29, 2009 Lee,Works perfectly! Thank you very much. You saved me a lot of time trying to figure this out on my own. No probs cabltv, - your LISP requests all seem much of a muchness, but good practice all the same Quote
blue-drafter Posted May 18, 2015 Posted May 18, 2015 I have a similar need to the above post. I need to transfer the balance of an attribute string to another block. I have attached an AutoCAD file with the table of information to transfer to the part tag block. ATT-TRANSFER.dwg Quote
BIGAL Posted May 19, 2015 Posted May 19, 2015 Not really sure what you want but you can do just about anything with multiple blocks its just a case of identifying them, in your case are you saying a block with a lable MM01 is to be updated but exists 55 times ? Just as a reference we have a pit schedule updator that can take info from all over the place but updates the single schedule no matter where it is in the drawing again just a case of block names & tags. Do a bit more research on updating attributes automatically. Quote
blue-drafter Posted May 19, 2015 Posted May 19, 2015 Bigal, I attached a new CAD file with directions of what I need. thanks BOM.dwg Quote
