Hi,
I need a lisp which can export only circles and arcs length to excel.
And when doing this must sort them by low length to high length.
for example first five rows of the excel file which will create with lisp :) :
Rank          Length           Type
1                  25                   circle
2                  33                   circle
3                  41                   arc
4                  54                   circle
As you can see five rows are like this. Five, that's mean that excel file must include titles either :)
thanks in advance.
I really appreciate all of you
trully regards
Major Tom
Try this you need to set up the correct file path for output, makes a csv file open in excel. Remove the remark ; to run once path is set.
(defun c:test ( / x y lay lst fo )
(setq lay (vla-get-layer (vlax-ename->vla-object (car (entsel "Pick Arc.circ for layer")))))
(setq ss (ssget (list (cons 0 "Arc,circle")(cons 8 lay))))
(setq lst '())
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(if (= (vla-get-objectname obj) "AcDbCircle")
(setq len (vla-get-circumference obj))
(setq id "Circle")
(setq len (vla-get-arclength obj))
(setq id "ARC")
(setq lst (cons (list id len) lst))
(setq lst (vl-sort lst '(lambda (x y)
(< (cadr x)(cadr y)))
(alert "ok now write a csv file you must change path below")
(setq lst (reverse lst))
(setq y 1)
(setq fo (open (setq fname "C:\\yourdiredctory\\yourfilename.csv") "w"))
(write-line "Rank,Length,Type" fo)
(repeat (setq x (length lst))
(setq ans (nth (setq x (- x 1)) lst))
(write-line (strcat (rtos y 2 0) "," (car ans) "," (rtos (cadr ans) 2 2)) fo)
(setq y (+ y 1))
(close fo)
(vl-load-com)
(c:test)
Edited by BIGAL
3 hours ago, BIGAL said:
Is double clicking on the csv to hard ?
;(setq fo (open (setq fname "C:\\yourdiredctory\\yourfilename.csv") "w"))
;(write-line "Rank,Length,Type" fo)
;(repeat (setq x (length lst))
;(setq ans (nth (setq x (- x 1)) lst))
;(write-line (strcat (rtos y 2 0) "," (car ans) "," (rtos (cadr ans) 2 2)) fo)
;(setq y (+ y 1))
;(close fo)
@BIGAL just notice you have commented ";"  in your code , that's why it doesn't write file ;)
here's another quick & dirty using vlax-curve- function
(defun c:CA (/ *error* l ls f fn i ss fn)
  (defun *error* (msg)
    (if (= (type f) 'FILE)
      (close f)
    (terpri)
  (if (and (setq i  0
                 ss (ssget "_X" (list '(0 . "ARC,CIRCLE") (cons 410 (getvar 'CTAB))))
           (setq ls (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))));(acet-ss-to-list ss))
           (setq fn (vl-filename-mktemp "CA.csv"))
           (setq f (open fn "W"))
           (write-line "Rank,Length,Type" f)
    (progn (setq i  0
                 l  (mapcar ''((x)
                               (list (vlax-curve-getDistAtParam x (vlax-curve-getEndParam x)) (cdr (assoc 0 (entget x))))
                            ls
                 ls (vl-sort l ''((a b) (< (car a) (car b))))
           (foreach x ls
             (write-line
               (apply 'strcat
                      (mapcar ''((x) (strcat x ",")) (list (itoa (setq i (1+ i))) (rtos (car x) 2) (cadr x)))
               f
             (close f)
      (vl-cmdf "_START" fn)
    (princ "\nOops.. Nothing?")
Edited by hanhphuc
commented by dlnorh sort length ascending
;(setq y (+ y 1))
;(close fo)
(defun c:CA (/ *error* en f i ss fn)
      (close f)
    (terpri)
  (if (and (setq i  0
           (setq n (sslength ss))
    (while (< i n)
      (setq en (ssname ss i))
      (write-line
        (apply 'strcat
                             (rtos (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)) 2)
                             (cdr (assoc 0 (entget en)))
        f
    (if (=(type f)'FILE) (close f) )
    ;;; (vl-cmdf "_SHELL" (strcat "explorer \""fn"\"") )
    (princ "\nOops..Nothing?")
  (*error* nil)
  (c:CA)
Missing the "sort by length" ascending 😛
  • Thanks 1
oops.. thanks 😅
If OP knows EXCEL well, just get it sorted in opened csv file
select range (example=$A$1:$C$6) -> insert Table -> sort A-Z at column 'length' -> renumber 'column 'Rank'
Edited by hanhphuc
Can't you open the file in excel using
(startapp "excel.exe" fname)
or something similar?
The braincell is telling me there is a method but I can't put my finger on it at the moment.
(startapp "EXPLORER" fname ) ;; open full path fname using its default app
FWIW If what you mean similar without COM API, normally just use command START or SHELL
(command "_START" "EXCEL")
Edited by hanhphuc
  • Like 2
Thanks @hanhphuc
(setq lst '())
(setq id "Circle")
(setq id "ARC")
(setq y 1)
(setq y (+ y 1))
(close fo)
(c:test)
how can i solve this bigal thank you by the way
thanks all of you guys for helping people who needs help like me
Put
(vl-load-com)
At the top of Al's file and reload, unless you are running on a MAC. If you are going to use lisp, it might be an idea to put this into one of the lisps that load automatically when AutoCAD starts, that way it is always there.
I probably should add (vl-load-com) to every file.
Also remove the "alert" line once paths are changed, it just so many times people do not understand that the code must be changed to save the file.
Ps (command "_START" "EXCEL C:/yourdiredctory/yourfilename.csv") will open the file
Edited by BIGAL
Hi again :)
Actually aI put the vl-load-com but still error comes in front of me
https://i.hizliresim.com/5N0zZM.jpg
Just copy and paste the code to notepad edit the destination file then save the file. Just drag and drop onto Autocad it will load.
Note this will not work with plines
Paste this line onto command line, pick circles and arcs
(setq ss (ssget (list (cons 0 "Arc,circle"))))
then type (sslength ss) a number should appear if not then you do not have circles and arcs but something else.
This will not work also if you have a MAC.
Post a sample dwg.
Edited by BIGAL
You may wish to consider the following code:
(defun c:c2xl ( / *error* col enx flg hed idx lst row sel typ xls xlsapp xlscls xlswbk xlswbs xlswsh )
    (setq hed '("Rank" "Length" "Type")) ;; Column headings
    (defun *error* ( msg )
        (if (and flg (= 'vla-object (type xlsapp)))
            (vl-catch-all-apply 'vlax-invoke-method (list xlsapp 'quit))
        (foreach obj (list xlscls xlswsh xlswbk xlswbs xlsapp)
            (if (and (= 'vla-object (type obj)) (not (vlax-object-released-p obj)))
                (vlax-release-object obj)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
    (cond
        (   (not
                (and
                    (setq sel (ssget '((0 . "ARC,CIRCLE"))))
                    (setq xls (getfiled "Create Excel File" "" "xlsx;xls" 1))
        (   (progn
                (repeat (setq idx (sslength sel))
                    (setq idx (1- idx)
                          enx (entget (ssname sel idx))
                          typ (strcase (cdr (assoc 0 enx)) t)
                          lst
                        (cons
                            (list
                                (*  (cdr (assoc 40 enx))
                                    (if (= "circle" typ)
                                        (+ pi pi)
                                        (rem (+ pi pi (- (cdr (assoc 51 enx)) (cdr (assoc 50 enx)))) (+ pi pi))
                                typ
                            lst
                (not
                    (or (setq xlsapp (vlax-get-object "excel.application"))
                        (and (setq xlsapp (vlax-create-object "excel.application"))
                             (setq flg t)
            (princ "\nUnable to interface with Excel application.")
        (   t
            (setq xlswbs (vlax-get-property  xlsapp 'workbooks)
                  xlswbk (vlax-invoke-method xlswbs 'add)
                  xlswsh (vlax-get-property  xlswbk 'activesheet)
                  xlscls (vlax-get-property  xlswsh 'cells)
            (setq col 0)
            (foreach itm hed
                (vlax-put-property xlscls 'item 1 (setq col (1+ col)) itm)
                (vlax-put-property
                    (vlax-get-property
                        (vlax-variant-value (vlax-get-property xlscls 'item 1 col))
                        'font
                    'bold :vlax-true
            (setq row 1)
            (foreach itm (vl-sort lst '(lambda ( a b ) (< (car a) (car b))))
                (setq row (1+ row)
                      col 0
                (foreach val (cons (1- row) itm)
                    (vlax-put-property xlscls 'item row (setq col (1+ col)) val)
            (if (and (< "11.0" (vlax-get-property xlsapp 'version))
                     (= (strcase (vl-filename-extension xls) t) ".xlsx")
                (vlax-invoke-method xlswbk 'saveas xls    51 "" "" :vlax-false :vlax-false 1 1)
                (vlax-invoke-method xlswbk 'saveas xls -4143 "" "" :vlax-false :vlax-false 1 1)
            (vlax-invoke-method xlswbk 'close :vlax-false)
    (*error* nil)
(vl-load-com) (princ)
  • Thanks 1
nice example Lee, had small issue with diffent excel versions with a 'little lunch time appie' and your code elegantly takes this into account. Thank for yet another lesson master Lee 🤓
Thanks @rlx, glad it helps. :)
