If you can get the co-ords and the insbase point of the block, then current insertion point you can work out a offset to add to the vertices.
You can use the command: NCOPY then retrieve the coordinate of the derived polyline from the block.
Unfortunately, the AutoCad substitute does not have this function
"Unable to recognize command "NCOPY". This error can occur when the command is not supported for the active license."
The NCOPY command is included with the Express Tools and apparently you don't have them installed with your AutoCAD version.
Sorry I didn't write at first, I use bricscad
The following routine should print the coordinates of all polylines that on layer "Boundary" in the selected block to the command line.
NOTE: Be sure to have all your layers unlocked.
(defun c:Test (/ sel lst pts)
  ;;	Tharwat - 26.Oct.2019	;;
  (and (setq sel (car (entsel "\nSelect a Block :")))
       (or (= (cdr (assoc 0 (entget sel))) "INSERT")
           (alert "Selected object is not a block <!>")
       (setq lst (vlax-invoke (vlax-ename->vla-object sel) 'Explode))
       (mapcar
         '(lambda (obj)
            (and (= (vla-get-objectname obj) "AcDbPolyline")
                 (= (vla-get-layer obj) "Boundary")
                 (setq
                   pts (cons (mapcar 'cdr
                                     (vl-remove-if-not
                                       '(lambda (p) (= (car p) 10))
                                       (entget (vlax-vla-object->ename obj))
                             pts
         lst
       (mapcar 'vla-delete lst)
  (if pts
    (princ pts)
) (vl-load-com)
For what it's worth, it is not necessary to perform a nested copy of the polyline, nor explode the block reference in order to ascertain the polyline vertex coordinates with respect to the block reference - instead, you can transform the polyline vertices obtained from the block definition using the position, scale, rotation & orientation of the block reference. This is a very similar question to that posed in this thread.
To offer an example, consider the following code:
(defun c:test ( / ent enx lst ocs )
    (while
        (progn (setvar 'errno 0) (setq ent (car (entsel "\nSelect block: ")))
            (cond
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (null ent)
                    nil
                (   (/= "INSERT" (cdr (assoc 0 (setq enx (entget ent)))))
                    (princ "\nThe selected object is not a block.")
                (   (null (setq lst (blockreferencepolylinevertices ent)))
                    (princ "\nThe selected block does not contain a 2D polyline on the Boundary layer.")
                (   (progn
                        (setq ocs (cdr (assoc 210 enx)))
                        (entmake
                            (append
                                (list
                                   '(000 . "LWPOLYLINE")
                                   '(100 . "AcDbEntity")
                                   '(100 . "AcDbPolyline")
                                    (cons 090 (length lst))
                                   '(070 . 0)
                                    (cons 038 (cadddr (assoc 010 enx)))
                                    (cons 210 ocs)
                                (mapcar '(lambda ( p ) (cons 10 (trans p 0 ocs))) lst)
                    nil
                (   (princ "\nUnable to recreated nested polyline."))
(defun blockreferencepolylinevertices ( ref / elv ent enx lst ocs )
   (setq ent (tblobjname "block" (cdr (assoc 2 (entget ref)))))
   (while
       (and
           (null lst)
           (setq ent (entnext ent))
       (if
           (and
               (= "LWPOLYLINE" (cdr (assoc 0 enx)))
               (= "BOUNDARY" (strcase (cdr (assoc 8 enx))))
           (setq elv (cdr (assoc 038 enx))
                 lst
               (mapcar
                  '(lambda ( v )
                       (trans (list (cadr v) (caddr v) elv) ocs 0)
                   (vl-remove-if-not '(lambda ( x ) (= 10 (car x))) enx)
   (if lst
       (apply
           (function
               (lambda ( mat vec )
                   (mapcar
                       (function
                           (lambda ( vtx )
                               (mapcar '+ (mxv mat vtx) vec)
                       lst
           (refgeom ref)
;; RefGeom (gile)
;; Returns a list whose first item is a 3x3 transformation matrix and
;; second item the object insertion point in its parent (xref, block or space)
(defun refgeom ( ent / ang enx mat ocs )
          ang (cdr (assoc 050 enx))
    (list
        (setq mat
            (mxm
                (mapcar '(lambda ( v ) (trans v 0 ocs t))
                        (1.0 0.0 0.0)
                        (0.0 1.0 0.0)
                        (0.0 0.0 1.0)
                (mxm
                    (list
                        (list (cos ang) (- (sin ang)) 0.0)
                        (list (sin ang) (cos ang)     0.0)
                       '(0.0 0.0 1.0)
                    (list
                        (list (cdr (assoc 41 enx)) 0.0 0.0)
                        (list 0.0 (cdr (assoc 42 enx)) 0.0)
                        (list 0.0 0.0 (cdr (assoc 43 enx)))
        (mapcar '- (trans (cdr (assoc 10 enx)) ocs 0)
            (mxv mat (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 enx))))))
;; Matrix Transpose  -  Doug Wilson
;; Args: m - nxn matrix
(defun trp ( m )
    (apply 'mapcar (cons 'list m))
;; Matrix x Matrix  -  Vladimir Nesterovsky
;; Args: m,n - nxn matrices
(defun mxm ( m n )
    ((lambda ( a ) (mapcar '(lambda ( r ) (mxv a r)) m)) (trp n))
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
Edited by Lee Mac
  • Thanks 1
  • 3 years later...
Hi Mr. Lee,
Thank you for the above code. Is there any code to create layers for these blocks automatically just after I created them?
  • 1 year later...
    (while
            (cond
                (   (null ent)
                    nil
                (   (progn
                        (entmake
                            (append
                                (list
                                   '(070 . 0)
                                    (cons 210 ocs)
                    nil
   (while
       (and
           (null lst)
       (if
           (and
                 lst
               (mapcar
                  '(lambda ( v )
   (if lst
       (apply
           (function
               (lambda ( mat vec )
                   (mapcar
                       (function
                           (lambda ( vtx )
                       lst
           (refgeom ref)
;; RefGeom (gile)
    (list
        (setq mat
            (mxm
                        (1.0 0.0 0.0)
                        (0.0 1.0 0.0)
                        (0.0 0.0 1.0)
                (mxm
                    (list
                       '(0.0 0.0 1.0)
                    (list
(defun trp ( m )
(defun mxm ( m n )
(defun mxv ( m v )
Hi @Lee Mac,
Is it possible to do this for all the blocks under the same name? Just to minimize the time selecting it one by one.
Thank you.
