Sambuddy Posted October 21, 2019 Posted October 21, 2019 I have found this LISP on another website to input inches in metric environment. Question: is it possible to use similar methods to upon executing the command (say PL1), start pline in inches in a metric cad file? I do realize that some of you would comment why not convert it after you draw it or why not scale... I just needed to know if there is a way to draw in this way?? Thanks, ;An offset command in inches ;If you have to do an offset while ;in an metric drawing this does it (defun C:2( / d) (setq d (getdist "Input distance (in): ")); in inches (setq d (* d 25.40)) ; converts it to mm (command "._offset" d) ;sends value to offset command ) Quote
Sambuddy Posted October 21, 2019 Author Posted October 21, 2019 (defun c:PL1(/ d p1 s) (setq d (getreal "Input (in): "))(terpri) (setq p1 (getpoint "Pick first point" ))(terpri) (setq s (* d 25.4)) (command "._pline" p1 ....... s) <something to draw from here on with the conversion> (princ) ) Quote
BIGAL Posted October 21, 2019 Posted October 21, 2019 (edited) If you treat it as a transparent command may work with some commands. (defun c:2 ( /)(* (getreal) 25.4)) eg line startpt drag mouse '2 4 drag '2 6 eg pline startpt '2 4 '2 6 '2 6 '2 5 c One thing though living in the land of metric depending on what your building should rounding be considered ? Would you build 100 or 101.6 a foot is 304 mm should you do it 300 mm if using say cut timber sheets they are exactly mm sizes like 1200x900 not 1219.2 x914.4 that 14.4mm would be a real problem 19.2 even bigger problem. Edited October 21, 2019 by BIGAL Quote
Sambuddy Posted October 22, 2019 Author Posted October 22, 2019 This is great BIGAL. it seems there is nothing you cannot do. It is actually nice to see that this works on all commands. Job WELL DONE!- so here is the follow up question... Is it then possible to have '3 for inputting feet&inches, example '2 4&8 = 4 feet and 8 inches (1st * 304.8 & 2nd * 25.4) ? Thanks again Quote
BIGAL Posted October 22, 2019 Posted October 22, 2019 Try (defun c:3 ( / ) (command (+ (* (getreal) 304.8 )(* (getreal) 25.4))) ) Quote
hanhphuc Posted October 22, 2019 Posted October 22, 2019 (edited) On 10/22/2019 at 1:35 AM, Sambuddy said: I have found this LISP on another website to input inches in metric environment. Question: is it possible to use similar methods to upon executing the command (say PL1), start pline in inches in a metric cad file? I do realize that some of you would comment why not convert it after you draw it or why not scale... I just needed to know if there is a way to draw in this way?? Thanks, ;An offset command in inches ;If you have to do an offset while ;in an metric drawing this does it (defun C:2( / d) (setq d (getdist "Input distance (in): ")); in inches (setq d (* d 25.40)) ; converts it to mm (command "._offset" d) ;sends value to offset command ) hi without code try: CAL Command: _offset Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0 Specify offset distance or [Through/Erase/Layer] <3.000>: 'cal >>>> Expression: 24.5*3 Resuming OFFSET command. Specify offset distance or [Through/Erase/Layer] <3.000>: 73.5 example 3'ft 4"inch or use global variable f=foot i=inch Command: (setq f 304.8 i 25.4) 25.4 Command: cal >> Expression: 3*f+4*i 1016 Edited October 23, 2019 by hanhphuc Quote
BIGAL Posted October 23, 2019 Posted October 23, 2019 (edited) Hanhphuc cal has a heap of smart functions and is hardly ever used. I often use it to just do like multiply. you can do all sorts of things like 2 * rad for offset etc. bit slow though if having to type all the time. The better way is to do a draw by brg distance function. This is one I prepared earlier said the chef ; input feet then inches then fractions as many as required. ; 123.11.5 is 123 feet 11 inches + 0.5 of a inch 3/8 is 0.375 Another maybe Edited October 23, 2019 by BIGAL Quote
hanhphuc Posted October 23, 2019 Posted October 23, 2019 (edited) 49 minutes ago, BIGAL said: Hanhphuc cal has a heap of smart functions and is hardly ever used. I often use it to just do like multiply. you can do all sorts of things like 2 * rad for offset etc. bit slow though if having to type all the time. The better way is to do a draw by brg distance function. This is one I prepared earlier said the chef ; input feet then inches then fractions as many as required. ; 123.11.5 is 123 feet 11 inches + 0.5 of a inch 3/8 is 0.375 Another maybe nice @BIGAL it would be nice extra DEG MIN SEC format slightly tweak from this old thread adding argument for scale factor (dt_dd_mm_ss 25.4 "0.19685 36 52 12") returns (4.99999 0.643503) ;distance & angle (related to user units sysvar i.e: angdir , angbase) ;function (defun dt_dd_mm_ss (f str / l) ; return list (dist angle) (if (and str (setq l (read (strcat "(" str ")"))) (vl-every 'numberp l) (and (<= 0. (cadr l)) (< (cadr l) 360.)) (vl-every ''((x) (and (<= 0. x) (< x 60.))) (cddr l)) ) (list (* (car l) f) (angtof (apply 'strcat (mapcar ''((a b c) (strcat (rtos a 2 c) b)) (cdr l) '("d" "'" "\"") '(0 0 2)) ) ) ) ) ) ;;example simulate command line: (defun c:myline (/ p1 p2 l *error*) (defun *error* (msg) nil) (setq p1 (getpoint "\nSpecify 1st point: ")) (while (setq p2 (if (vl-consp (setq p2 (getpoint p1 "\nSpacebar for [_dist_dd_mm_ss] : "))) p2 (progn (while (not (setq l (dt_dd_mm_ss 25.4 (getstring t "\nINCH_dd_mm_ss : \n"))))) (apply 'polar (cons p1 (reverse l))) ) ) ) (entmakex (list '(0 . "LINE") (cons 10 (trans p1 1 0)) (cons 11 (trans p2 1 0)))) (setq p1 p2) ) (princ) ) Edited October 23, 2019 by hanhphuc Quote
BIGAL Posted October 23, 2019 Posted October 23, 2019 (edited) Hanhphuc your right about the bearing I normally use ddd.mmss have done so since the 1990's. Working in metric just makes life so much easier. Here in Aus we have old land titles down to 1/4", then there are roods and chains to worry about. Nice routine though combing the distance and bearing into a string. I would have used dist.dec,DDD.mmss so no problems with a space terminating a string input. If you want end result as pline do a cons of (entlast) as you make lines can then join them into a pline at end or pedit last and join new as you go. The multi getvals.lsp above can have the default reset every time if you want for distance and bearing save a bit of typing as you may say do repeated brg's but different lengths. It can though be all to no avail, for here in say AUS, old towers would have been built to say inch standard, new towers are possibly now true metric sizes. A lot of stuff though is still built to old standards. Edited October 23, 2019 by BIGAL Quote
hanhphuc Posted October 24, 2019 Posted October 24, 2019 (edited) On 10/23/2019 at 11:32 AM, BIGAL said: If you want end result as pline do a cons of (entlast) as you make lines can then join them into a pline at end or pedit last and join new as you go. or make it transparent for polyline or others command move etc.. (defun c:dd ( / str ) (if (and (setq str (getstring t "\nDISTANCE_dd_mm_ss : ")) (setq l (dt_dd_mm_ss 1.0 str))) (apply 'polar (cons (getvar 'lastpoint) (reverse l)))(princ)) ) example drawing triangle: Command: (vl-cmdf "-units" 2 3 2 4 90 "Y" ) <-- 2=Degrees/minutes/seconds ... ... Command: PLINE Specify start point: 0,0 Current line-width is 0.0000 Specify next point or [Arc/Halfwidth/Length/Undo/Width]: 'dd DIST_dd_mm_ss : 5 36 52 12 <-- dist dd mm ss (3.00001 3.99999 0.0) Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: 3 <-- mouse pointing to west or polar tracking Specify next point or [Arc/Close/Halfwidth/Length/Undo/Width]: 'dd DIST_dd_mm_ss : 4 180 (7.14566e-006 -5.35926e-006 0.0) Command: MOVE Select objects: 1 found Select objects: Specify base point or [Displacement] <Displacement>: Specify second point or <use first point as displacement>: 'dd DIST_dd_mm_ss : 5 36 52 12 <-- should apply -ve distance? bug? (3.00001 3.99999 0.0) Edited October 24, 2019 by hanhphuc syntax color , delete comment Quote
BIGAL Posted October 24, 2019 Posted October 24, 2019 I think we need Sambuddy to step up. maybe Ft.inch,DDD.mmss 3.3,180.0 3 feet 3 inches but does not support fractions Hmm another problem. Quote
