Pugazh Posted October 21, 2019 Posted October 21, 2019 (edited) Hi, i need this block point. please see attached file. Edited October 21, 2019 by Pugazh Quote
Emmanuel Delay Posted October 21, 2019 Posted October 21, 2019 How do we know the length between the block insert point and the point you're looking for? 1 Quote
Pugazh Posted October 21, 2019 Author Posted October 21, 2019 (edited) On 10/21/2019 at 7:25 AM, Emmanuel Delay said: How do we know the length between the block insert point and the point you're looking for? Expand This point taken from i have to make xline from block center point to block insert point then i get from intersection point (xline with outer polyline). Original code is here https://www.cadtutor.net/forum/topic/68870-move-text-to-line-along-text-rotation/?do=findComment&comment=556625 This code is created by @dlanorh, i just modified. (defun rh:sammlung_n (o_lst grp / tmp n_lst) (setq n_lst nil) (cond ( (and o_lst (= (rem (length o_lst) grp) 0)) (while o_lst (repeat grp (setq tmp (cons (car o_lst) tmp) o_lst (cdr o_lst))) (setq n_lst (cons (reverse tmp) n_lst) tmp nil) );end_while ) );end_cond (if n_lst (reverse n_lst)) );end_defun (vl-load-com) (defun c:test ( / *error* c_doc c_spc l_obj ent e_lst ss t_obj i_pt t_rot x_obj x_pts s_d x_pt) (defun *error* ( msg ) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg))) (princ) );end_defun *error* (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) c_spc (vlax-get-property c_doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) );end_setq (while (not l_obj) (setq ent (car (entsel "\nSelect Line : ")) e_lst (entget ent) );end_setq (if (vl-position (cdr (assoc 0 e_lst)) (list "ARC" "LINE" "LWPOLYLINE" "RAY" "SPLINE" "XLINE")) (setq l_obj (vlax-ename->vla-object ent))) );end_while (if (and (princ "\nSelect Bars: ")(setq ss (ssget ":L" '((0 . "INSERT")(2 . "`*U*")))) ) (repeat (setq cnt (sslength ss)) (setq hnd (ssname ss (setq cnd (1- cnt)))) (vla-getboundingbox (vlax-ename->vla-object hnd) 'minpt 'maxpt) (setq t_obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) i_pt (mapcar '/ ; midpoint of bounding box (mapcar '+ (vlax-safearray->list minpt) (vlax-safearray->list maxpt)) '(2 2 2) ); mapcar i_pt2 (cdr (assoc 10 (entget hnd)))) (command "_.snapang" "_non" i_pt "_non" i_pt2) (setq ang (getvar 'snapang)) (setq x_obj (vlax-invoke c_spc 'addxline i_pt (polar i_pt ang 1.0)) x_pts (rh:sammlung_n (vlax-invoke x_obj 'intersectwith l_obj acextendnone) 3) s_d 1.0e200 );end_setq (cond ( (> (length x_pts) 1) (foreach pt x_pts (if (< (distance pt i_pt) s_d) (setq x_pt pt s_d (distance pt i_pt))))) (t (setq x_pt (car x_pts))) );end_cond (vla-delete x_obj) ...................... ...................... );end_repeat ) (princ) );end_defun Edited October 21, 2019 by Pugazh Quote
Emmanuel Delay Posted October 23, 2019 Posted October 23, 2019 I keep having this same question. From what you're asking I don't know how far that point must be from the block. Look at this code, made for the dwg attachment. I have different blocks, with different rotations, and a rectangle. My code puts a point on the rectangle. It also puts a point along that same line at a distance 25 (Assuming your image has a text height of 2.5, those points you want are at that distance) Command BFP (defun drawPoint (pt) (entmakex (list (cons 0 "POINT") (cons 10 pt))) ) (defun drawLine (p1 p2) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; Intersections - Lee Mac ;; Returns a list of all points of intersection between two objects ;; for the given intersection mode. ;; ob1,ob2 - [vla] VLA-Objects ;; mod - [int] acextendoption enum of intersectwith method ;; acextendnone Do not extend either object ;; acextendthisentity Extend obj1 to meet obj2 ;; acextendotherentity Extend obj2 to meet obj1 ;; acextendboth Extend both objects (defun LM:intersections ( ob1 ob2 mod / lst rtn ) (if (and (vlax-method-applicable-p ob1 'intersectwith) (vlax-method-applicable-p ob2 'intersectwith) (setq lst (vlax-invoke ob1 'intersectwith ob2 mod)) ) (repeat (/ (length lst) 3) (setq rtn (cons (list (car lst) (cadr lst) (caddr lst)) rtn) lst (cdddr lst) ) ) ) (reverse rtn) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; (defun c:bfp ( / rect blocks i l p1 rot p2 p3) (princ "\nSelect blocks: ") (setq blocks (ssget (list (cons 0 "INSERT")))) (setq rect (car (entsel "\nSelect rectangle: "))) ;; I'll extend a line to at least outside the rectangle. Using the length of the rectangle guarantees this (setq len (vla-get-length (vlax-ename->vla-object rect))) (setq i 0) (repeat (sslength blocks) ;; make a dummy line, we'll erase it later (setq l (drawLine (setq p1 (cdr (assoc 10 (entget (ssname blocks i))))) (polar p1 (setq rot (cdr (assoc 50 (entget (ssname blocks i))))) len) )) ;; find intersect with rectangle (setq p2 (nth 0 (LM:intersections (vlax-ename->vla-object l) (vlax-ename->vla-object rect) acextendnone))) (drawPoint p2) (setq p3 (vlax-curve-getPointAtDist (vlax-ename->vla-object l) 25.0)) (drawPoint p3) ;; delete the line (entdel l) (setq i (+ i 1)) ) ) Please try to explain again what exactly you need. block_rect.dwgFetching info... 1 Quote
Pugazh Posted October 24, 2019 Author Posted October 24, 2019 Hi @Emmanuel Delay, This is i need, how to get block nearest endpoint or perpendicular point from the entsel. (list "ARC" "LINE" "LWPOLYLINE" "RAY" "SPLINE" "XLINE")) See my attached file, the blocks are selected. did you see block insert point?. blocks insert point is enough for me but they blocks are have different rotation. So i need block endpoint from the entsel. Quote
dlanorh Posted October 24, 2019 Posted October 24, 2019 On 10/24/2019 at 5:48 AM, Pugazh said: Hi @Emmanuel Delay, This is i need, how to get block nearest endpoint or perpendicular point from the entsel. (list "ARC" "LINE" "LWPOLYLINE" "RAY" "SPLINE" "XLINE")) See my attached file, the blocks are selected. did you see block insert point?. blocks insert point is enough for me but they blocks are have different rotation. So i need block endpoint from the entsel. Expand Blocks don't have endpoints, only insertion points. So lets assume these are dimensions (they are saved as anonymous blocks), is that correct? 1 Quote
Pugazh Posted October 27, 2019 Author Posted October 27, 2019 Hi @dlanorh, Sorry for the late reply, maybe these are dimensions (they are saved as anonymous blocks). please see the attached sample file. Block.dwgFetching info... Quote
dlanorh Posted October 27, 2019 Posted October 27, 2019 Iannot open this drawing, It needs to be in AutoCAD 2010 format Quote
Pugazh Posted October 27, 2019 Author Posted October 27, 2019 On 10/27/2019 at 9:09 AM, dlanorh said: Iannot open this drawing, It needs to be in AutoCAD 2010 format Expand Block.dwgFetching info... Quote
dlanorh Posted October 27, 2019 Posted October 27, 2019 (edited) Try this. Tested with your block, and will only work with this block. It is an in-elegant short notice solution. The block is composed of a line and four nested blocks. The block is copied, the copy is then exploded and nested blocks removed leaving the line. The end points of the line are tested against the original blocks insertion point and the non-matching coordinate is returned. All created objects are deleted. (defun rh:oppend ( obj / n_obj b_objs l_obj s_pt e_pt rtn) (if (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj))) (cond ( (= "AcDbBlockReference" (vlax-get obj 'objectname)) (setq n_obj (vla-copy ent) b_objs (vlax-invoke n_obj 'explode) l_obj (car (vl-remove-if-not '(lambda (x) (= (vlax-get x 'objectname) "AcDbLine")) b_objs)) s_pt (vlax-get l_obj 'startpoint) e_pt (vlax-get l_obj 'endpoint) ) (vla-delete n_obj) (mapcar '(lambda (x) (vla-delete x)) b_objs) (if (equal (vlax-get obj 'insertionpoint) s_pt 0.001) (setq rtn e_pt) (setq rtn s_pt)) ) );end_cond rtn );end_defun ;; ##### HOW TO USE ##### (setq e_pt (rh:oppend entity)) ; will accept a block entity or a block object. The return (the point you want) will be in the variable e_pt) Edited October 27, 2019 by dlanorh Quote
Pugazh Posted October 27, 2019 Author Posted October 27, 2019 (edited) On 10/21/2019 at 7:44 AM, Pugazh said: This point taken from i have to make xline from block center point to block insert point then i get from intersection point (xline with outer polyline). Original code is here https://www.cadtutor.net/forum/topic/68870-move-text-to-line-along-text-rotation/?do=findComment&comment=556625 This code is created by @dlanorh, i just modified. (defun rh:sammlung_n (o_lst grp / tmp n_lst) (setq n_lst nil) (cond ( (and o_lst (= (rem (length o_lst) grp) 0)) (while o_lst (repeat grp (setq tmp (cons (car o_lst) tmp) o_lst (cdr o_lst))) (setq n_lst (cons (reverse tmp) n_lst) tmp nil) );end_while ) );end_cond (if n_lst (reverse n_lst)) );end_defun (vl-load-com) (defun c:test ( / *error* c_doc c_spc l_obj ent e_lst ss t_obj i_pt t_rot x_obj x_pts s_d x_pt) (defun *error* ( msg ) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg))) (princ) );end_defun *error* (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) c_spc (vlax-get-property c_doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) );end_setq (while (not l_obj) (setq ent (car (entsel "\nSelect Line : ")) e_lst (entget ent) );end_setq (if (vl-position (cdr (assoc 0 e_lst)) (list "ARC" "LINE" "LWPOLYLINE" "RAY" "SPLINE" "XLINE")) (setq l_obj (vlax-ename->vla-object ent))) );end_while (if (and (princ "\nSelect Bars: ")(setq ss (ssget ":L" '((0 . "INSERT")(2 . "`*U*")))) ) (repeat (setq cnt (sslength ss)) (setq hnd (ssname ss (setq cnd (1- cnt)))) (vla-getboundingbox (vlax-ename->vla-object hnd) 'minpt 'maxpt) (setq t_obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) i_pt (mapcar '/ ; midpoint of bounding box (mapcar '+ (vlax-safearray->list minpt) (vlax-safearray->list maxpt)) '(2 2 2) ); mapcar i_pt2 (cdr (assoc 10 (entget hnd)))) (command "_.snapang" "_non" i_pt "_non" i_pt2) (setq ang (getvar 'snapang)) (setq x_obj (vlax-invoke c_spc 'addxline i_pt (polar i_pt ang 1.0)) x_pts (rh:sammlung_n (vlax-invoke x_obj 'intersectwith l_obj acextendnone) 3) s_d 1.0e200 );end_setq (cond ( (> (length x_pts) 1) (foreach pt x_pts (if (< (distance pt i_pt) s_d) (setq x_pt pt s_d (distance pt i_pt))))) (t (setq x_pt (car x_pts))) );end_cond (vla-delete x_obj) ...................... ...................... );end_repeat ) (princ) );end_defun Expand i add this line. it's correct? (setq e_pt (rh:oppend hnd)) Edited October 27, 2019 by Pugazh Quote
dlanorh Posted October 27, 2019 Posted October 27, 2019 (edited) On 10/27/2019 at 12:06 PM, Pugazh said: i add this line. it's correct? (setq e_pt (rh:oppend hnd)) Expand Yes, but you don't have to use e_pt as the variable name; you can use whatever variable name makes sense to you. You also need to include the sub function in with the rest of the code. Edited October 27, 2019 by dlanorh Quote
Pugazh Posted October 28, 2019 Author Posted October 28, 2019 i got this Error : bad argument type: VLA-OBJECT Quote
hanhphuc Posted October 28, 2019 Posted October 28, 2019 On 10/28/2019 at 4:43 AM, Pugazh said: i got this Error : bad argument type: VLA-OBJECT Expand (setq n_obj (vla-copy ent) (vla-copy obj) 1 Quote
Pugazh Posted October 28, 2019 Author Posted October 28, 2019 On 10/28/2019 at 6:35 AM, hanhphuc said: (setq n_obj (vla-copy ent) (vla-copy obj) Expand (defun rh:oppend ( obj / n_obj b_objs l_obj s_pt e_pt rtn) (if (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj))) (cond ( (= "AcDbBlockReference" (vlax-get obj 'objectname)) (setq n_obj (vla-copy obj) b_objs (vlax-invoke n_obj 'explode) l_obj (car (vl-remove-if-not '(lambda (x) (= (vlax-get x 'objectname) "AcDbLine")) b_objs)) s_pt (vlax-get l_obj 'startpoint) e_pt (vlax-get l_obj 'endpoint) ) (vla-delete n_obj) (mapcar '(lambda (x) (vla-delete x)) b_objs) (if (equal (vlax-get obj 'insertionpoint) s_pt 0.001) (setq rtn e_pt) (setq rtn s_pt)) ) );end_cond rtn );end_defun i just checked (setq e_pt (rh:oppend (ssget))) I got same Error : bad argument type: VLA-OBJECT Quote
hanhphuc Posted October 28, 2019 Posted October 28, 2019 On 10/28/2019 at 7:40 AM, Pugazh said: (defun rh:oppend ( obj / n_obj b_objs l_obj s_pt e_pt rtn) (if (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj))) (cond ( (= "AcDbBlockReference" (vlax-get obj 'objectname)) (setq n_obj (vla-copy obj) b_objs (vlax-invoke n_obj 'explode) l_obj (car (vl-remove-if-not '(lambda (x) (= (vlax-get x 'objectname) "AcDbLine")) b_objs)) s_pt (vlax-get l_obj 'startpoint) e_pt (vlax-get l_obj 'endpoint) ) (vla-delete n_obj) (mapcar '(lambda (x) (vla-delete x)) b_objs) (if (equal (vlax-get obj 'insertionpoint) s_pt 0.001) (setq rtn e_pt) (setq rtn s_pt)) ) );end_cond rtn );end_defun i just checked (setq e_pt (rh:oppend (ssget))) I got same Error : bad argument type: VLA-OBJECT Expand It's different time zone, i think @dlanorh will soon reply if he wakes up, so please be patient. His rh:oppend sub function requires single ENAME or VLA-OBJECT type as argument, not a PICKSET (selectionset) (rh:oppend (car(entsel)) ) ; ENAME (rh:oppend (ssname (ssget) 0)) ; first item in selection set you can use repeat, while, foreach loop to iterate in selection set. 1 Quote
dlanorh Posted October 28, 2019 Posted October 28, 2019 On 10/28/2019 at 6:35 AM, hanhphuc said: (setq n_obj (vla-copy ent) (vla-copy obj) Expand Thanks, Don't know how I missed that one. Quote
Pugazh Posted October 28, 2019 Author Posted October 28, 2019 hi @dlanorh, Thank you so much i think my question is not possible Quote
dlanorh Posted October 28, 2019 Posted October 28, 2019 On 10/28/2019 at 7:40 AM, Pugazh said: (defun rh:oppend ( obj / n_obj b_objs l_obj s_pt e_pt rtn) (if (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj))) (cond ( (= "AcDbBlockReference" (vlax-get obj 'objectname)) (setq n_obj (vla-copy obj) b_objs (vlax-invoke n_obj 'explode) l_obj (car (vl-remove-if-not '(lambda (x) (= (vlax-get x 'objectname) "AcDbLine")) b_objs)) s_pt (vlax-get l_obj 'startpoint) e_pt (vlax-get l_obj 'endpoint) ) (vla-delete n_obj) (mapcar '(lambda (x) (vla-delete x)) b_objs) (if (equal (vlax-get obj 'insertionpoint) s_pt 0.001) (setq rtn e_pt) (setq rtn s_pt)) ) );end_cond rtn );end_defun i just checked (setq e_pt (rh:oppend (ssget))) I got same Error : bad argument type: VLA-OBJECT Expand You said in an earlier post Quote This is i need, how to get block nearest endpoint or perpendicular point from the entsel. Expand You cannot send it a selection set. As @hanhphuc mentioned you will need to process any selection set in a loop (repeat (setq cnt (sslength ss)) (setq e_pt (rh:oppend (ssname ss (setq cnt (1- cnt))))) ;; ;; ;;Rest of your code here to do what you want ;; ;; );end_repeat I don't know what you are trying to do with the points you have. Perhaps an explanation would help. Quote
