Draw panels using vba or excel
I want to draft panels using VBA or EXCEL data, anyone give the script for the same,
 i have attached drafting flow here, please see attached cad file.
A Panel.dwg
This would be the method  etc its all been done before mainly in lisp.
Get get say lower left point. Length &  width draw a pline 4 sides
Draw 4 plines that are the green offsets you know the co-ords of the 4 corner points.
Take the Length /400 get x.xx you take the fix and work out the odd end measurements
Draw the circles top bottom
Work out the width = /400 etc
Draw the circles.
(defun c:panel ( / len wid pt1 pt2 pt3 pt4)
(setq pt1 (getpoint "\nPick lower left Corner"))
(setq Len (Getreal "\nEnter length"))
(setq wid (Getreal "\nWidth"))
(setq pt2 (polar Pt1 0.0 len))
(setq pt3 (polar pt2 (/ pi 2.0) wid))
(setq pt4 (polar pt3 pi len))
(command "pline" pt1 pt2 pt3 pt4 "c")
(C:panel)
Ok so for green lines do a change layer (setvar 'clayer "greenlines")
you work out 3 new pts using polar command again (setq pt5 (polar pt1 (* 1.5 pi) off))
work out pt6
then (command "pline" pt1 pt5 pt6 pt2 "")
redo for 3 other sides
(setq num (fix (- (/ len 400.0) 1)))
(setq off2 ( / (- len (* num 400.0)) 2.0))
Now work out some more points for the circles
do again for 3 other sides
Draw the circles.
(C:panel)
work out pt6
this is only rectangle script, please could you provide me script for whole object
