Hi,
I am looking to find a way to show a field which shows the total length of different colour polylines and automatically updates as I add or remove those lines.
For example the field would be based on displaying the total length of all polylines that are colour 10 in the drawing.
Another field doing the same for colour 30 etc.
This would help with costing once the full design as been done.
Ideally I would add field at the end of each legend below to show the total length of each line in the drawing.
Thanks,
To auto-update for new lines, you'll have to create a Reactor in some sort.
On 10/22/2019 at 6:30 AM, BIGAL said:
Field
FYI
SPLINE not supported
distance in 3D
(defun c:test (/ l s p)
  (and (setq s (ssget '((0 . "*LINE")))) ;SPLINE not supported!
       (setq l (ACET-SS-TO-LIST s))
       (setq p (getpoint "\nSpecify point.. "))
       (entmakex
         (mapcar 'cons
                 '(0 40 10 1)
                 (list "TEXT"
                       (getvar 'textsize)
                       p
                       (apply 'strcat
                              (append (cons "%<\\AcExpr ("
                                            (mapcar ''((x / vo )
                                                       (strcat
                                                        "%<\\AcObjProp Object(%<\\_ObjId "
                                                        (itoa (vla-get-ObjectID (setq vo (vlax-ename->vla-object x))))
                                                        ">%)."(if (vlax-property-available-p vo 'arclength)"arc" "")
                                                        "length>%+"
                                                    l
                                      '("0.0) \\f %lu2%pr3>%")
  (vl-cmdf "_.regen")
sorry ET loop
credits: field expression which strcat "+0.0" (plus zero) simple idea was inspired by @Stefan BMR
Nice one
Maybe do a few more as part of a single defun that returns length, Circle 'circumference &  Arc 'arclength of object.
Could use the multiple toggles to choose normal items plus say layer or layers. Allow user pick
(if (not AH:Toggs)(load "Multiple toggles.lsp"))
(setq ans (ah:toggs '("Please Choose" " Lines" " LwPlines" " Arcs" " Circles" " Layer single" " Layers multiple" )))
  • 6 months later...
Hi BIGAL - I am interested in the VBA version of this routine. I am looking to have a form where the user can select polylines from the drawing and the total length of the polylines is displayed on the form. Is there any source code for the VBA version shown above?
Thanks
