Pugazh Posted October 17, 2019 Share Posted October 17, 2019 (edited) (defun RtoD (nbrOfRadians) (/ (* nbrOfRadians 180.0) pi) ) (defun DtoR (nbrOfDegrees) (* (/ nbrOfDegrees 180.0) pi) ) (if (>= (cvunit (getvar 'snapang) "radians" "degrees") 180.0) (setvar 'snapang (- (cvunit (getvar 'snapang) "radians" "degrees") 180.0)) ) Hi, i think this code is totally wrong please help me! Edited October 17, 2019 by Pugazh Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 17, 2019 Author Share Posted October 17, 2019 (defun RtoD (nbrOfRadians) (/ (* nbrOfRadians 180.0) pi) ) (defun DtoR (nbrOfDegrees) (* (/ nbrOfDegrees 180.0) pi) ) (if (>= (cvunit (getvar 'snapang) "radians" "degrees") 180.0) (command "_.snapang" (- (cvunit (getvar 'snapang) "radians" "degrees") 180.0)) ) This code is working fine Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 17, 2019 Share Posted October 17, 2019 The code could alternatively be written: (if (<= pi (getvar 'snapang)) (setvar 'snapang (- (getvar 'snapang) pi)) ) Or simply: (setvar 'snapang (rem (getvar 'snapang) pi)) 2 Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 19, 2019 Author Share Posted October 19, 2019 (edited) thanks @Lee Mac Edited October 19, 2019 by Pugazh Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 19, 2019 Author Share Posted October 19, 2019 Hi @Lee Mac, i have some doubt about snapang. please see the attached file. i want as per attached image have two condition in one lisp code it's possible? (must be check the two condition at the same time) Quote Link to comment Share on other sites More sharing options...
dlanorh Posted October 19, 2019 Share Posted October 19, 2019 (if (< (/ pi 2) (getvar 'snapang) (* (/ pi 2) 3)) (setvar 'snapang (+ (getvar 'snapang) pi))) 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 19, 2019 Share Posted October 19, 2019 Alternatively, without if statements: (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0))) 1 1 Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 20, 2019 Author Share Posted October 20, 2019 Wow !! Exactly i needed this one thank you @dlanorh & @Lee Mac cheers Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 29, 2019 Author Share Posted October 29, 2019 How to combine ? one if condition (if (< (/ pi 2) (getvar 'snapang) (* (/ pi 2) 3)) (setvar 'snapang (+ (getvar 'snapang) pi))) (if (= (getvar 'snapang) (/ pi 2)) (setvar 'snapang (/ pi 2))) (if (= (getvar 'snapang) (* (/ pi 2) 3)) (setvar 'snapang (/ pi 2))) Quote Link to comment Share on other sites More sharing options...
tombu Posted October 29, 2019 Share Posted October 29, 2019 (edited) (if (= (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))(* (/ pi 2) -1))(setvar 'snapang (/ pi 2))) Now it works! Edited October 29, 2019 by tombu coding error 1 Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 30, 2019 Author Share Posted October 30, 2019 14 hours ago, tombu said: (if (= (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))(* (/ pi 2) -1))(setvar 'snapang (/ pi 2))) Now it works! thank you @tombu Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 30, 2019 Author Share Posted October 30, 2019 I have another doubt! If i set snapang any angle, it should be automatically change to as per autocad dimension text rotation. it's possible ? Quote Link to comment Share on other sites More sharing options...
tombu Posted October 30, 2019 Share Posted October 30, 2019 (edited) As I do Civil / Survey drawings whose plan views are all twisted in each viewport I wrote this to set selected block insert, text, mtext, & dimtext angles Horizontal. I've modified it for you to use the snap angle if the view isn't twisted. ;| ;| https://forums.augi.com/showthread.php?171018-rotate-text-to-horizontal-in-viewport&p=1332928&viewfull=1#post1332928 http://www.theswamp.org/index.php?topic=55060.msg595136#msg595136 https://www.cadtutor.net/forum/topic/68912-setvar-snapang-using-lisp-with-greater-than-or-equal-condition/?tab=comments#comment-557172 Set block insert, text, mtext, & dimtext angle Horizontal by Tom Beauford (load "TextHoriz.lsp") TextHoriz Macro: ^P(or C:TextHoriz (load "TextHoriz.lsp"));TextHoriz Command line: (load "TextHoriz.lsp") TextHoriz |; (defun c:TextHoriz (/ ss1 num cnt viewtwist snapang etype obj dimr) (setq ss1 (ssget '((0 . "insert,mtext,text,dimension"))) num (sslength ss1) cnt 0 viewtwist (getvar "viewtwist") snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)) ) (if (or (= snapang (* (/ pi 2) -1)) (= snapang (* (/ pi 2) 3)))(setvar 'snapang (/ pi 2))) (if(/= viewtwist 0.0) (repeat num (setq ent (ssname ss1 cnt)etype (cdr(assoc 0 (entget ent)))) (setq obj (vlax-ename->vla-object ent)) (if(= etype "DIMENSION") (progn (setq dimr (- (vla-get-Rotation obj)viewtwist)) (vla-put-TextRotation obj dimr) ) (vla-put-Rotation obj (- viewtwist)) ) (setq cnt (1+ cnt)) ) ; repeat (repeat num (setq ent (ssname ss1 cnt)etype (cdr(assoc 0 (entget ent)))) (setq obj (vlax-ename->vla-object ent)) (if(= etype "DIMENSION") (progn (setq dimr (+ (vla-get-Rotation obj)snapang)) (vla-put-TextRotation obj dimr) ) (vla-put-Rotation obj snapang) ) (setq cnt (1+ cnt)) ) ; repeat ; (princ "\nNo TWist in Viewport.") ) ; if (princ) ) Edited October 30, 2019 by tombu Updated to fix both snapang 270 or -90. 1 Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 30, 2019 Author Share Posted October 30, 2019 Thank you @tombu!! I think my question is wrong , How to take snap angle in aligned dimensions text rotation ? if i draw dimension text automatically rotated as per snap angle. i need this snap angle code with if conditions like this (if (= (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))(* (/ pi 2) -1))(setvar 'snapang (/ pi 2))) Quote Link to comment Share on other sites More sharing options...
tombu Posted October 30, 2019 Share Posted October 30, 2019 5 minutes ago, Pugazh said: Thank you @tombu!! I think my question is wrong , How to take snap angle in aligned dimensions text rotation ? if i draw dimension text automatically rotated as per snap angle. i need this snap angle code with if conditions like this (if (= (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))(* (/ pi 2) -1))(setvar 'snapang (/ pi 2))) I modified the code for that 38 minutes ago, have you tried the updated code? Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 30, 2019 Author Share Posted October 30, 2019 (command "_.snapang" "_non" pt1 "_non" pt2) (if (= (setvar 'snapang (- (rem (+ (getvar 'snapang) (/ pi 2.0)) pi) (/ pi 2.0)))(* (/ pi 2) -1))(setvar 'snapang (/ pi 2))) @tombu , I did not change rotation. I have two points, pt1 is block mid point, pt2 is block insert point. now snapang is 270 from the pt1 & pt2. i use this code sometimes update snapangle 90 but sometimes not update why i know Quote Link to comment Share on other sites More sharing options...
tombu Posted October 30, 2019 Share Posted October 30, 2019 (edited) On 10/29/2019 at 5:04 AM, Pugazh said: How to combine ? one if condition I've updated the code to correct snapang of either (* (/ pi 2) 3) or (* (/ pi 2) -1). Edited October 30, 2019 by tombu 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 30, 2019 Share Posted October 30, 2019 @Pugazh Assuming I've understood what you are looking to achieve, is this program of use to you? 1 Quote Link to comment Share on other sites More sharing options...
Pugazh Posted October 31, 2019 Author Share Posted October 31, 2019 10 hours ago, Lee Mac said: @Pugazh Assuming I've understood what you are looking to achieve, is this program of use to you? thank you lee i got it your code Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 31, 2019 Share Posted October 31, 2019 7 hours ago, Pugazh said: thank you lee i got it your code Excellent - you're most welcome 1 Quote Link to comment Share on other sites More sharing options...
