Count objects at a specific distance
Anushka
Hello everyone, Is there a way to count only objects at a specific distance?
Example I have several blocks in my drawing and I want to count only those that are at the maximum distance X, from a RED, CIAN polyline ... and delete all others, How to do this?
In the attached dwg example, I want to delete only those with the green circle.
Thanks in advance for the help you are giving me !!
Drawing1.dwg
Hi,
Something like this?
(defun c:Test (/ int cnt sel ent get bks lws lst len)
  ;;	Tharwat - Date: 14.Oct.2019	;;
  (and (or *gapdis* (setq *gapdis* 1.0))
       (or (initget 6)
           (setq *gapdis*
                  (cond
                    ((getdist
                       (strcat
                         "\nSpecify maximum gap distance between blocks and polylines <"
                         (vl-princ-to-string *gapdis*)
                    (*gapdis*)
       (princ "\nSelect Blocks & Polylines : ")
       (setq int -1
             cnt 0
             sel (ssget "_:L" '((0 . "LWPOLYLINE,INSERT")))
       (while (setq int (1+ int)
                    ent (ssname sel int)
         (or (and (= (cdr (assoc 0 (setq get (entget ent)))) "INSERT")
                  (setq bks (cons get bks))
             (setq lws (cons ent lws))
       (mapcar
         '(lambda (w)
            (mapcar
              '(lambda (b / p)
                 (and (setq lst b)
                      (or (< (setq
                               len (distance (vlax-curve-getclosestpointto w (setq p (cdr (assoc 10 b)))) p)
                             *gapdis*
                          (equal len *gapdis* 1e-4)
                      (setq cnt (1+ cnt))
                      (setq bks (vl-remove lst bks))
              bks
         lws
       (and bks (foreach bk bks (entdel (cdr (assoc -1 bk)))))
  (princ (strcat "\nNumber of blocks retained [ " (if (< 0 cnt) (itoa cnt) "None") " ]."))
) (vl-load-com)
  • Thanks 1
