UNWANTED LINES IN MY WORK SPACE
I was using AutoCAD 2010 for my work before now, after my system crashed and I installed a new operating system, I upgraded my CAD version to 2017. Since then, I started seeing some lines in my work space which are not in my drawings.
If I print the drawings, those lines are not there. However, this is not so If I start a fresh drawing.
Attached here is a sample of what I am referring to.
Best regards,
Abakam, Abakam
CHALLENGE.docx
Actually "Turning off Hardware Acceleration" is not a "cure", but a workaround of the true problem.
You need a better graphics card or a different driver to "cure" the problem if possible on your computer.
What are the specifications for your computer, graphics card and driver?
