Beginner bob Posted October 9, 2019 Share Posted October 9, 2019 i need to replicate this in autocad can anyone help me? im a total beginer and dont know much. i have no idea how to make those dashed lines and how to know the lenght of 2 middle lines, as well as how to posision circkles up top. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 10, 2019 Share Posted October 10, 2019 Dashed lines use a linetype that is dashed just happens that is what one is called, you may need to change linetype scale use properties. The circles appear to be at 45 degrees form centre. The verticals appear to match the top circles centres so draw a line from centre of each this will give top of line. Use offset for dashed line, use Intersection snap to find center of circles. 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 10, 2019 Share Posted October 10, 2019 The dashed lines are called Center lines. Doesn't appear to have all of the information, you'll need to insert in AutoCAD and scale it using Reference option and one of the given dimensions. Search here for Scale Reference and inserting Images, etc. 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 10, 2019 Share Posted October 10, 2019 You're right to be puzzled, this diagram is missing several vital dimensions. 1 Quote Link to comment Share on other sites More sharing options...
