Pugazh Posted October 9, 2019 Posted October 9, 2019 Hello Everyone ! The posted code is working fine as per the attached image. They text are move follow with green line direction but I need move text follow with magenta line direction in selected line or Polyline. Can anyone help me! Code : (Defun c:alt (/ li txts e) (if (and (princ "\nSelect Line for Alignment") (setq li (ssget "_:L" '((0 . "LINE")))) (princ "\nSelect Texts to Align") (setq txts (ssget "_:L" '((0 . "TEXT,MTEXT"))))) (repeat (sslength txts) (vla-move (setq e (vlax-ename->vla-object (ssname txts 0))) (vla-get-insertionpoint e) (vlax-3d-point (vlax-curve-getclosestpointto (ssname li 0) (vlax-get e 'insertionpoint))) ) (ssdel (ssname txts 0) txts) ) ) (princ) ) (vl-load-com) Quote
BIGAL Posted October 10, 2019 Posted October 10, 2019 (edited) Are you happy with move based on angle of text ? This would use a xline and intersectwith ; By Alan H Oct 2019 ; moves text along text angle to a *line (vl-load-com) (defun c:pushtxt ( / ss ang obj obj2 obj4 pt1 pt2 pt3 ent) (setq obj (vlax-ename->vla-object (car (entsel "pick Line ")))) (setq ss (ssget (list (cons 0 "*text")))) (repeat (setq x (sslength ss)) (setq ent (ssname ss (setq x (- x 1)))) (setq obj2 (vlax-ename->vla-object ent )) (setq Pt1 (vlax-get Obj2 'Insertionpoint)) (setq ang (vlax-get Obj2 'rotation)) (setq pt3 (polar pt1 ang 10)) (command "xline" pt1 pt3 "") (setq obj4 (vlax-ename->vla-object (entlast))) (setq intpt (vlax-invoke obj 'intersectWith obj4 acExtendboth)) (vla-delete obj4) (command "move" ent "" pt1 intpt) ) ) (c:pushtxt) Edited October 11, 2019 by BIGAL 1 Quote
dlanorh Posted October 10, 2019 Posted October 10, 2019 As the OP wants to move to a line or pline I can see a problem arising if the xline cuts the pline more than once, when intpt will become a list min length 6 (2 points), so you would have to find the nearest intersection point. 1 Quote
dlanorh Posted October 10, 2019 Posted October 10, 2019 On 10/10/2019 at 8:18 AM, Pugazh said: @BIGAL No not working Expand How is it not working? What error message are you getting? Are you trying to use this with a polyline or a line? If with a polyline try it with a line. Is the visual lisp arx loaded? If not put (vl-load-com) at the top of the file and try again 1 Quote
Pugazh Posted October 10, 2019 Author Posted October 10, 2019 @dlanorh Yeah i'm try with line but they text are not move in line. I got some error See the attached file . Quote
dlanorh Posted October 10, 2019 Posted October 10, 2019 On 10/10/2019 at 10:11 AM, Pugazh said: @dlanorh Yeah i'm try with line but they text are not move in line. I got some error See the attached file . Expand Try this (defun rh:sammlung_n (o_lst grp / tmp n_lst) (setq n_lst nil) (cond ( (and o_lst (= (rem (length o_lst) grp) 0)) (while o_lst (repeat grp (setq tmp (cons (car o_lst) tmp) o_lst (cdr o_lst))) (setq n_lst (cons (reverse tmp) n_lst) tmp nil) );end_while ) );end_cond (if n_lst (reverse n_lst)) );end_defun (vl-load-com) ;; Move Text to Line along text rotation (defun c:MT2L ( / *error* c_doc c_spc l_obj ent e_lst ss t_obj i_pt t_rot x_obj x_pts s_d x_pt) (defun *error* ( msg ) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg))) (princ) );end_defun *error* (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) c_spc (vlax-get-property c_doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) );end_setq (while (not l_obj) (setq ent (car (entsel "\nSelect Line : ")) e_lst (entget ent) );end_setq (if (vl-position (cdr (assoc 0 e_lst)) (list "ARC" "LINE" "LWPOLYLINE" "RAY" "SPLINE" "XLINE")) (setq l_obj (vlax-ename->vla-object ent))) );end_while (setq ss (ssget '((0 . "*TEXT")))) (repeat (setq cnt (sslength ss)) (setq t_obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) i_pt (vlax-get t_obj 'insertionpoint) t_rot (vlax-get t_obj 'rotation) x_obj (vlax-invoke c_spc 'addxline i_pt (polar i_pt t_rot 1.0)) x_pts (rh:sammlung_n (vlax-invoke x_obj 'intersectwith l_obj acextendnone) 3) s_d 1.0e200 );end_setq (cond ( (> (length x_pts) 1) (foreach pt x_pts (if (< (distance pt i_pt) s_d) (setq x_pt pt s_d (distance pt i_pt))))) (t (setq x_pt (car x_pts))) );end_cond (vlax-invoke t_obj 'move i_pt x_pt) (vla-delete x_obj) );end_repeat (princ) );end_defun It will move the text to the nearest intersection (if more than 1) using the text angle. See attached dwg MT2L.dwgFetching info... 1 Quote
BIGAL Posted October 11, 2019 Posted October 11, 2019 (edited) I just tested again and working fine is the angle of the text such that a intersection point is not visually calculated ? This will force a calculation extending lines replaced in code above (setq intpt (vlax-invoke obj 'intersectWith obj4 acExtendboth)) Edited October 11, 2019 by BIGAL 1 Quote
Pugazh Posted October 12, 2019 Author Posted October 12, 2019 Thank you so much!! yeah both code are now working fine Cheers @BIGAL @dlanorh Quote
hanhphuc Posted October 16, 2019 Posted October 16, 2019 (edited) another by math algorithm & entmod without 'vla-move' & 'vlax-intersectwith' select texts then pick a line (defun c:test (/ ok ss en enx np l x y i p) (if (and (princ "\nSelect Texts to Align ") (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT")))) (setq en (car (entsel "\nSelect LINE.."))) (setq enx (entget en)) (= (cdr (assoc 0 enx)) "LINE") (setq l (mapcar ''((x) (cdr (assoc x enx))) '(10 11) ) x (vl-sort l ''((a b) (<= (car a) (car b)))) y (vl-sort l ''((a b) (<= (cadr a) (cadr b)))) ) ) (progn (repeat (setq i (sslength ss)) (setq enx (entget (ssname ss (setq i (1- i))))) (setq c (if (or (= (cdr (assoc 0 enx)) "MTEXT") (equal (setq p (cdr (assoc 11 enx))) '(0.0 0.0 0.0) 1e-7) ) 10 11 ) ) (setq p (cdr (assoc c enx))) (and (setq ok (or (setq np (hp:IntersOnX p x)) ;(setq np (hp:IntersOnY p y)) ) ) (entmod (subst (cons c np) (cons c p) enx)) (grdraw (trans np 0 1) (trans p 0 1) 2) ) ) (if (not ok) (princ "\nSorry.. out of range!") ) ) (princ "\nOops.. please retry ") ) (princ) ) (defun hp:IntersOnX (p l / xy) ;hanhphuc (setq xy '((x)(mapcar '* x '(1.0 1.0))) p (xy p)) (cadr (assoc T (cons (list (vl-some ''((x)(equal p (xy x) 1e-4)) l) p) (mapcar ''((a b / d )(setq d (xy (mapcar '- b a))) (list (<= (car a) (car p) (car b)) (list (car p) (+ (cadr a) (* (- (car p) (car a)) (if (vl-some 'zerop d) 0. (/ 1. (apply '/ d )))))) ) ) l (cdr l) ) ) ) ) ) Edited October 16, 2019 by hanhphuc 1 Quote
Pugazh Posted October 17, 2019 Author Posted October 17, 2019 On 10/10/2019 at 8:26 PM, dlanorh said: Try this (defun rh:sammlung_n (o_lst grp / tmp n_lst) (setq n_lst nil) (cond ( (and o_lst (= (rem (length o_lst) grp) 0)) (while o_lst (repeat grp (setq tmp (cons (car o_lst) tmp) o_lst (cdr o_lst))) (setq n_lst (cons (reverse tmp) n_lst) tmp nil) );end_while ) );end_cond (if n_lst (reverse n_lst)) );end_defun (vl-load-com) ;; Move Text to Line along text rotation (defun c:MT2L ( / *error* c_doc c_spc l_obj ent e_lst ss t_obj i_pt t_rot x_obj x_pts s_d x_pt) (defun *error* ( msg ) (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error occurred : " msg))) (princ) );end_defun *error* (setq c_doc (vla-get-activedocument (vlax-get-acad-object)) c_spc (vlax-get-property c_doc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) );end_setq (while (not l_obj) (setq ent (car (entsel "\nSelect Line : ")) e_lst (entget ent) );end_setq (if (vl-position (cdr (assoc 0 e_lst)) (list "ARC" "LINE" "LWPOLYLINE" "RAY" "SPLINE" "XLINE")) (setq l_obj (vlax-ename->vla-object ent))) );end_while (setq ss (ssget '((0 . "*TEXT")))) (repeat (setq cnt (sslength ss)) (setq t_obj (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) i_pt (vlax-get t_obj 'insertionpoint) t_rot (vlax-get t_obj 'rotation) x_obj (vlax-invoke c_spc 'addxline i_pt (polar i_pt t_rot 1.0)) x_pts (rh:sammlung_n (vlax-invoke x_obj 'intersectwith l_obj acextendnone) 3) s_d 1.0e200 );end_setq (cond ( (> (length x_pts) 1) (foreach pt x_pts (if (< (distance pt i_pt) s_d) (setq x_pt pt s_d (distance pt i_pt))))) (t (setq x_pt (car x_pts))) );end_cond (vlax-invoke t_obj 'move i_pt x_pt) (vla-delete x_obj) );end_repeat (princ) );end_defun It will move the text to the nearest intersection (if more than 1) using the text angle. See attached dwg MT2L.dwg 61.96 kB · 5 downloads Expand Hi @dlanorh, I have to add some changes can you please help me!! Above this code after creating xline, i want to move or offset xline (clockwise direction) distance is taken from dimscale. Quote
dlanorh Posted October 18, 2019 Posted October 18, 2019 Sorry I can't help at the moment as I am away and I don't have any version of AutoCAD etc with me. Will be back at the end of next week. 1 Quote
Pugazh Posted October 19, 2019 Author Posted October 19, 2019 On 10/18/2019 at 7:53 AM, dlanorh said: Sorry I can't help at the moment as I am away and I don't have any version of AutoCAD etc with me. Will be back at the end of next week. Expand i will be waiting Quote
