BIGAL Posted October 9, 2019 Share Posted October 9, 2019 (edited) I found my self trying to write a simple install routine and something that would work inside Autocad. I did find that you can unzip and direct the contents to a specific directory, so my in my case have 42 fas files around 40 dwgs a menu or two , numerous dcl's and Slb's. It just needs a simple bat file, it finds the zip in "downloads" the normal save as location etc Md c:\Cadarc powershell.exe -nologo -noprofile -command "& { Add-Type -A 'System.IO.Compression.FileSystem'; IO.Compression.ZipFile]::ExtractToDirectory('C:\users\%username%\downloads\cadarc.zip', 'C:\Cadarc'); }" The next is to wrapper it using "Shell" in a lisp that also sets the support and trusted paths, loads the menu's and makes a workspace, possibly a ARG for if anything goes wrong. Trying to get end users to make directories add support paths can be a nightmare if they have never done it. Edited October 9, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
rlx Posted October 9, 2019 Share Posted October 9, 2019 Looks interesting Bigal. Will play with it when I have the time (suddenly everybody is giving me work here at the office... how dare you! ) Quote Link to comment Share on other sites More sharing options...
CHLUCFENG Posted October 10, 2019 Share Posted October 10, 2019 Interesting to use a batch file through shell. I'll have to keep that in mind. At our company, there is a master lisp routine that loads where we can add tidbits as necessary. One small portion adds the support paths for FONTS, TRUSTED PATHS, and PLOTTER/PEN settings. Here's how I worked through that: (defun TrustedPath (/ AcadObject PrefsObject TabNameObject SupPath TrustPath) (vl-load-com) (setq AcadObject (vlax-get-acad-object)) (setq PrefsObject (vlax-get-property AcadObject 'Preferences)) ;store a reference to Preferences (Preferences object) (setq TabNameObject (vlax-get-property PrefsObject 'Files)) ;Store a reference to the Files (Files Object) (setq SupPath (strcase (vlax-get-property TabNameObject 'SupportPath)) ) ;get the existing support path (CAPS) ;; check for FONTS (if (not (vl-string-search "K:\\FONTS" SupPath)) (progn (princ "\nFonts are not listed in Support Path") (setq SupPath (strcat SupPath ";" "K:\\fonts")) ;; Update the path (vlax-put-property TabNameObject 'SupportPath SupPath) (alert " The FONTS in your support path did not include K:\Fonts. \n\t\tI have added the support path. \n\tPlease close all AutoCAD sessions and re-open." ) ) ;end progn ;;else (princ "\nCheck - Fonts are pathed.") ) ;end if ;;; Directories for Trusted Paths (defun check (str) (if (not (vl-string-search str (strcase (getvar "trustedpaths"))) ) (setvar "trustedpaths" (strcat (getvar "trustedpaths") ";" str ";") ) ) ) (mapcar 'check '("K:\\..." "U:\\CHUCK\\LISP" "U:\\CHUCK\\LISP\\..." ) ) (princ "\nTrusted paths checked... Loaded as necessary.") ;;; Directories for Plotter configurations and pen settings (setq SupPath (strcase (vlax-get-property TabNameObject 'PrinterConfigPath) ) ) (if (not (vl-string-search "ACAD2018 PLOTTING" SupPath) ) (progn (princ "\nPrinter configuration path loading...") (setq SupPath (strcat SupPath ";" "K:\\Plotting;") ) ;; Update the path (vlax-put-property TabNameObject 'PrinterConfigPath SupPath) ) ;end progn ) ;end if (setq SupPath (strcase (vlax-get-property TabNameObject 'PrinterDescPath)) ) (if (not (vl-string-search "ACAD2018 PLOTTING" SupPath) ) (progn (princ "\nPrinter description path loading...") (setq SupPath (strcat SupPath ";" "K:\\Plotting;") ) ;; Update the path (vlax-put-property TabNameObject 'PrinterDescPath SupPath) ) ;end progn ) ;end if (setq SupPath (strcase (vlax-get-property TabNameObject 'PrinterStyleSheetPath) ) ) (if (not (vl-string-search "ACAD2018 PLOTTING" SupPath) ) (progn (princ "\nPlot style table path loading...") (setq SupPath (strcat SupPath ";" "K:\\Plotting;") ) ;; Update the path (vlax-put-property TabNameObject 'PrinterStyleSheetPath SupPath ) ) ;end progn ) ;end if ;;; Directory for Autosave Path (if (not (= (strcase (getvar "savefilepath")) "C:\\ACAD-AUTOSAVE") ) (progn (setvar "savefilepath" "C:\\ACAD-AUTOSAVE") (princ "\nAutosave path checked... Changed as necessary.") ) ) (princ) ) ; end TrustedPath The hardest part of this task was getting the correct property names. 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 11, 2019 Author Share Posted October 11, 2019 (edited) Thanks CHULFENG I have the paths plus a few other items all sorted when you have to build around 20 autocad per year need shortcuts. (vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) will give list of properties. A couple worth adding Acadtemp is my dump directory (vla-put-TempFilePath *files* "C:\\AcadTemp\\") (vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\") (vla-put-LogFilePath *files* "C:\\AcadTemp\\") Edited October 11, 2019 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
CHLUCFENG Posted October 11, 2019 Share Posted October 11, 2019 19 minutes ago, BIGAL said: (vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) Well, check that out! Shows me the properties, and their current path. Quite handy. Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
