bobbykimchi Posted October 4, 2019 Share Posted October 4, 2019 Hi, I am trying to find a way to label points with its own layer name like the attached lisp commando. It does it with line/polylines. Also I am trying to find a way to do this with multiple points, therefore the rotation of the imported mtext does not need to be aligned. Could anyone help me find a way to edit the code downstairs or help me with a new code? (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt ) ) ) ) (defun C:LL (/ *error* acsp adoc ang fld midp mtx rot sset txtpt) (defun *error* (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort" ) ) (princ "Error!") (princ msg) ) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object) ) ) (princ) ) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object) ) ) ) (if (and (= (getvar "tilemode") 0) (= (getvar "cvport") 1) ) (setq acsp (vla-get-paperspace adoc)) (setq acsp (vla-get-modelspace adoc)) ) (vla-startundomark adoc ) (if (setq sset (ssget "_:L" (list (cons 0 "*LINE,ARC,CIRCLE,ELLIPSE")))) (foreach obj (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex sset)))) (if (not (eq "AcDbArc" (vla-get-objectname obj))) (setq midp (vlax-curve-getclosestpointto obj (vlax-curve-getpointatparam obj ( / (- (vlax-curve-getEndParam obj) (vlax-curve-getStartParam obj)) 2)) ) ) (setq midp (vlax-curve-getclosestpointto obj (vlax-curve-getpointatdist obj ( / (vla-get-arclength obj) 2))) ) ) (setq ang (alg-ang obj midp)) (if (> pi ang (/ pi 2)) (setq ang (+ ang pi)) ) (if (> (* pi 1.5) ang pi) (setq ang (+ ang pi)) ) (setq rot (+ ang (/ pi 2))) (setq txtpt (polar midp rot (if (zerop (getvar "dimtxt")) 0.1 (/ (getvar "dimtxt") 2))) ) (setq fld (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-objectid obj)) ">%).Layer>%") ) (setq mtx (vlax-invoke acsp 'AddMText midp 0.0 fld) ) (vlax-put mtx 'AttachmentPoint 8 ) (vlax-put mtx 'InsertionPoint txtpt ) (vlax-put mtx 'Rotation ang ) ) ) (princ) ) (princ "\n\t\t\tType LL to label curves with layer name\t") (prin1) (vl-load-com) ll-Label A line with its own layer name.txt Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted October 4, 2019 Share Posted October 4, 2019 Like this? Command LL (defun M-Text (pt str ht) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 pt) (cons 40 ht) (cons 1 str))) ) (defun c:ll ( / points i point layer ip ht) (setq ht 2.5) ;; Text height. Feel free to pick your desired height (princ "\nSelect points: ") (setq points (ssget (list (cons 0 "POINT")))) (setq i 0) (repeat (sslength points) (setq layer (cdr (assoc 8 (entget (ssname points i))))) (setq ip (cdr (assoc 10 (entget (ssname points i))))) (M-Text ip layer ht) (setq i (+ i 1)) ) (princ) ) Or maybe you want the Mtext in the layer of the point? (Or any other extras?) 1 Quote Link to comment Share on other sites More sharing options...
rlx Posted October 4, 2019 Share Posted October 4, 2019 oh darn Emmanuel beat me to it, awell , at least (unlike me) he probably knows what he was doing lol....oh , that's the command , because don't want to redefine my own LL command (load lisp) (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt)))) (defun C:LoL (/ *error* acsp adoc ang fld midp mtx rot sset txtpt) (defun *error* (msg) (if (vl-position msg '("console break" "Function cancelled" "quit / exit abort")) (princ "Error!") (princ msg)) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (princ) ) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (if (and (= (getvar "tilemode") 0) (= (getvar "cvport") 1)) (setq acsp (vla-get-paperspace adoc)) (setq acsp (vla-get-modelspace adoc))) (vla-startundomark adoc) (if (setq sset (ssget "_:L" (list (cons 0 "point")))) (foreach obj (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex sset)))) ;(if (not (eq "AcDbArc" (vla-get-objectname obj))) ; (setq midp (vlax-curve-getclosestpointto obj (vlax-curve-getpointatparam obj ; (/ (- (vlax-curve-getEndParam obj)(vlax-curve-getStartParam obj)) 2)))) ; (setq midp (vlax-curve-getclosestpointto obj (vlax-curve-getpointatdist obj ; (/ (vla-get-arclength obj) 2))))) ;(setq ang (alg-ang obj midp)) (setq ang 0 midp (vlax-safearray->list (vlax-variant-value (vla-get-coordinates obj)))) (if (> pi ang (/ pi 2)) (setq ang (+ ang pi))) (if (> (* pi 1.5) ang pi) (setq ang (+ ang pi))) (setq rot (+ ang (/ pi 2))) (setq txtpt (polar midp (* pi 0.25) (if (zerop (getvar "dimtxt")) 2.5 (getvar "dimtxt")))) (setq fld (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-objectid obj)) ">%).Layer>%")) (setq mtx (vlax-invoke acsp 'AddMText midp 0.0 fld)) (vlax-put mtx 'AttachmentPoint (vlax-put mtx 'InsertionPoint txtpt) (vlax-put mtx 'Rotation ang) ) ) (princ) ) (princ "\n\t\t\tType LoL to label curves with layer name\t") (prin1) (vl-load-com) time (almost) to enjoy the weekend gr. R. 1 1 Quote Link to comment Share on other sites More sharing options...
bobbykimchi Posted October 4, 2019 Author Share Posted October 4, 2019 Thanks @Emmanuel Delay. Would be good to get it in the same layer if possible. Quote Link to comment Share on other sites More sharing options...
Emmanuel Delay Posted October 4, 2019 Share Posted October 4, 2019 Sure (defun M-Text (pt str ht lay) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 pt) (cons 40 ht) (cons 8 lay) (cons 1 str))) ) (defun c:ll ( / points i point layer ip ht) (setq ht 2.5) ;; Text height. Feel free to pick your desired height (princ "\nSelect points: ") (setq points (ssget (list (cons 0 "POINT")))) (setq i 0) (repeat (sslength points) (setq layer (cdr (assoc 8 (entget (ssname points i))))) (setq ip (cdr (assoc 10 (entget (ssname points i))))) (M-Text ip layer ht layer) (setq i (+ i 1)) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
toan.huynh Posted April 17, 2023 Share Posted April 17, 2023 @Emmanuel Delay can you repair code to show layer name under of line segment ? Please! Quote Link to comment Share on other sites More sharing options...
