Hi,
I need to edit "test.csv" as a "test MB.csv".
4th line and multiples give scale information. I removed it from "Test MB.csv" because I didn't need it.
Thanks for any help,
Truly Regards,
testt.lsp testt.csv testt MB.csv
best would be to save the right format to begin with but assuming you're already stuck with one :
; (chop '(1 2 3 4 5 6 7 8 9) 4) -> '((1 2 3 4) (5 6 7 8) (9))
(defun chop (l n / tl fl) (cond ((or (null l) (null n) (not (vl-consp l)) (not (numberp n)))) ((< (length l) n) l)
  (t (while (vl-consp l) (setq tl (cons (car l) tl))(if (= n (length tl))(setq fl (cons tl fl) tl nil))
       (if (and (not (vl-consp (setq l (cdr l))))(vl-consp tl))(setq fl (cons tl fl)))))) (reverse (mapcar 'reverse fl)))
; convert
(defun convert_csv_file (fn-in / fp-in fnl fn-out fp-out dat item lst)
  (if (and fn-in (findfile fn-in) (setq fp-in (open fn-in "r")) (setq fnl (fnsplitl fn-in))
           (setq fn-out (strcat (car fnl) (cadr fnl) " MB" (last fnl))) (setq fp-out (open fn-out "w")))
      ; first read entire file and put it in a list
      (while (setq dat (read-line fp-in))(setq lst (cons dat lst)))
      ; now chop-up list in pieces of 6 (based on posted example)
      (setq lst (chop (reverse lst) 6))
      ; org format posted :
      ;   MT-AR-FC-01-TW-GN-CD-0312 + 30.09.2019 + 1/2 + 0 + FT01 TYPICAL DETAIL 311 + ""
      ; desired format :
      ;   Drawing Number;Drawing Name;Date;Revision Number
      ;   MT-AR-FC-01-TW-GN-CD-0312;FT01 TYPICAL DETAIL 311;30.09.2019;0
      ; first save header
      (write-line "Drawing Number;Drawing Name;Date;Revision Number" fp-out)
      ; now write chopped up list
      ; we need item_0 + ";" + item_4 + ";" + item_1 + ";" + item_3
      (foreach item lst
        (write-line (strcat (nth 0 item) ";" (nth 4 item) ";" (nth 1 item) ";" (nth 3 item)) fp-out)
      (close fp-in)(close fp-out)(gc)
      (startapp "notepad" fn-out)
(defun c:t1 ( / fn)
  (if (setq fn (getfiled "select source csv file" "" "csv" 0)) (convert_csv_file fn))
haven't tested this one (since I have no drawing to test it on)
(defun c:t2 (/ *error* f o e ss i sn atl)
  (defun *error* (msg) (if o (close o)) (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")
    (princ msg) (princ (strcat "\n ** Error : " msg " **"))))
  (if (and (setq ss (ssget "X" '((0 . "INSERT") (66 . 1) (2 . "A1 ANTET"))))
           (setq f (getfiled "Specify Excel file name" (getvar 'dwgprefix) "csv" 1)) (setq o (open f "w")))
      ; write header "Drawing Number;Drawing Name;Date;Revision Number"
      (write-line "Drawing Number;Drawing Name;Date;Revision Number" o)
        (setq atl '() sn (ssname ss (setq i (1- i))))
        (while (and (setq sn (entnext sn)) (/= (cdr (assoc 0 (setq e (entget sn)))) "SEQEND"))
          (if (eq (cdr (assoc 0 e)) "ATTRIB")(setq atl (cons (cdr (assoc 1 e)) atl))))
        ; format posted   : (0) MT-AR-FC-01-TW-GN-CD-0312, (1) 30.09.2019, (2) 1/2, (3) 0, (4) FT01 TYPICAL DETAIL 311, (5)""
        ; format desired  : MT-AR-FC-01-TW-GN-CD-0312;FT01 TYPICAL DETAIL 311;30.09.2019;0
        (if (vl-consp atl) (write-line (strcat (nth 0 atl) ";" (nth 4 atl) ";" (nth 1 atl) ";" (nth 3 atl)) o))
  (if o (close o))
  (gc)
This isn't worked :(
Quote
; convert
      ; desired format :
      ; first save header
      (foreach item lst
(defun c:t1 ( / fn)
On 10/1/2019 at 6:56 PM, Lee Mac said:
Have you tried using the standard AutoCAD DATAEXTRACTION command?
On 10/2/2019 at 5:01 AM, BIGAL said:
Another simple is a lisp extract attributes to csv file. Just search.
; convert
      ; desired format :
      ; first save header
      (foreach item lst
(defun c:t1 ( / fn)
This can be helpful but onlly running in current layout I wanna same thng to all layouts
  (if o (close o))
  (gc)
Edited by MajorTom
rlx said haven't tested this one (since I have no drawing to test it on)
couldn't have said it better Bigal :danger:  hahaha 😄
so SSDD (same s..t , different day) : untested (and also have other work to do)
(defun c:t3 (/ *error* f o e ss i sn atl)
  (cond
    ((not (setq f (getfiled "Specify Excel file name" (getvar 'dwgprefix) "csv" 1)))
     (alert "No csv file was specified"))
    ((not (setq o (open f "w")))
     (alert "Unable to write to csv file"))
    (t
     (foreach lay (cons "Model" (layoutlist))
       (setvar "CTAB" lay)
       (if (setq ss (ssget "X" (list '(0 . "INSERT") '(66 . 1) '(2 . "A1 ANTET") (cons 410 (getvar "CTAB")))))
       (setq ss nil)
  (if o (close o))(gc)(startapp "notepad" f)
Edited by rlx
Updated code after testing on test block from me , myself and I
tested code during lunch and did a little update. Code in previous post modified.
Edited by rlx
Thank you rlx appreciate what you have done :)
