MajorTom Posted October 1, 2019 Posted October 1, 2019 Hi, I'm new around here so, I couldn't find the solutions please don't mad me if this request already written by someone else. And also sorry about my grammer either The thing what I want to do : I have a folder and this folder is include many dwg files. And these dwg files contetnts one or more layouts. I'm using Enhanced Attribute Editor for keep data like; <drawing number>, <drawing name>, <date>, <revision no> etc. So I need a lisp for export these data to an excel file . thanks in advance for any help Truly Regards Quote
Lee Mac Posted October 1, 2019 Posted October 1, 2019 Have you tried using the standard AutoCAD DATAEXTRACTION command? Quote
BIGAL Posted October 2, 2019 Posted October 2, 2019 Another simple is a lisp extract attributes to csv file. Just search. Quote
pkenewell Posted October 2, 2019 Posted October 2, 2019 (edited) Express Tools ATTOUT and ATTIN command? I have used these in the past with good results. ATTOUT creates a tab delimited text file, which can be imported by Excel. Edited October 2, 2019 by pkenewell Quote
MajorTom Posted October 3, 2019 Author Posted October 3, 2019 On 10/1/2019 at 3:56 PM, Lee Mac said: Have you tried using the standard AutoCAD DATAEXTRACTION command? Expand Data extractiontools wasn't enough cause if someone change the values which in the enhanced attribute editor. I wanna run the lisp and create an excel file in the same folder which include all enhanced attribute editor values. and some dwg has a more than one layout and almost all layout include an enhanced attribute editor. Quote
MajorTom Posted October 3, 2019 Author Posted October 3, 2019 On 10/2/2019 at 2:01 AM, BIGAL said: Another simple is a lisp extract attributes to csv file. Just search. Expand I think you talked about this am I right? How could I run tis code, cause it has no c : shortcut and when I trid to run this in vlisp untitled project "quit / exit abort" error comes on my front ; Global ATTribute EXtractor ; by Miklos Fuccaro mfuccaro@hotmail.com ;-------------------------November 2004 ------- ;;Edited March 2006 by C. Bassler to allow specification of block and tage names to extract (defun gattex () (setq Blocklist '("ENG")) ;; ** edit to include block names to select (setq TagList '("WEIGHT" "LABEL" )) ;; ** edit to include tag names to extract ;;create block names separated by columns, for selection filter (setq Blocknames (List2String BlockList)) (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 BlockNames)))) (if (not ss) (quit)) (setq Root (getvar "DWGPREFIX")) (setq file (open (strcat Root "attributes.CSV") "w") i -1) (write-line (strcat Root (getvar "DWGNAME") " -found " (itoa (sslength ss)) " block(s) with attributes") file) (repeat (sslength ss) (setq TagRow nil ValRow nil) (setq Edata (entget (setq e (ssname ss (setq i (1+ i)))))) (write-line "" file) (write-line (strcat "block name:" "," (Dxf 2 Edata)) file) (while (/= (Dxf 0 Edata) "SEQEND") (if (and (= (Dxf 0 Edata) "ATTRIB") (member (dxf 2 Edata) TagList) ;;if tag is on list ) ;and (progn (setq TagRow (cons (Dxf 2 Edata) TagRow)) (setq valRow (cons (Dxf 1 Edata) ValRow)) ) ;progn ) (setq Edata (entget (setq e (entnext e)))) ) ;while (write-line (List2String (reverse TagRow)) file) (write-line (List2String (reverse ValRow)) file) ) ;repeat (close file) (princ (strcat "\nDone writing file " Root "attributes.csv")) (princ) ) ;defun ;;------------------------------- (defun List2String (Alist) (setq NumStr (length Alist)) (foreach Item AList (if (= Item (car AList)) ;;first item (setq LongString (car AList)) (setq LongString (strcat LongString "," Item)) ) ) LongString ) ;defun ;;-------------------------------- (defun Dxf (code pairs) (cdr (assoc code pairs)) ) (gattex) Quote
MajorTom Posted October 3, 2019 Author Posted October 3, 2019 On 10/2/2019 at 1:56 PM, pkenewell said: Express Tools ATTOUT and ATTIN command? I have used these in the past with good results. ATTOUT creates a tab delimited text file, which can be imported by Excel. Expand I know actually this two command but like I said there is too many layouts in dwg and too many dwg in folder. when some changes happend in enhanced attribute editor.I wanna run the command (after delete old xls file) to creare my new xls file which include alll current values Quote
BIGAL Posted October 4, 2019 Posted October 4, 2019 (edited) If I understand correct you want the title block details exported for a multi layout dwg plus other info like dwg name, but it needs to process over a directory of dwgs. Just need the title block name, if you do not want all attributes then tag names required. An example change block name (defun c:test ( ) (setq blkname "DA1DRTXT") (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vlax-for lay (vla-get-Layouts doc) (setq lname (vla-get-name lay)) (princ "\n") (princ (strcat "layout = " lname)) (if (/= lname "Model") (progn (setvar 'ctab lname) (setq ss (ssget "x" (list (cons 0 "insert")(cons 2 blkname)(cons 410 lname)))) (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS 0 )) 'getattributes) (princ (strcat (vla-get-tagstring att) "," (vla-get-textstring att))) (princ "\n" ) ) ) ) ) ) (c:test) [/code] Edited October 4, 2019 by BIGAL Quote
