Reduce decimal points of absorbed ordinates.
(setq pt1 (getpoint"\n First corner ")); select all
(setq pt2 (getcorner pt1"\n 2nd corner"))
(setq ss (ssget"C"pt1 pt2  '((0 . "circle")) )); all circles
 (repeat   (setq i (sslength ss));repeat1
                   (setq i (1- i))
                   (setq     e (ssname ss i))
                   (setq   center (cdr (assoc 10 (entget e)))); centre of circle
       (setq x (car center));in mm
         (setq y (cadr center))
(command-s "text" (list 100 100) 100  0 x)
The inserted X value is 2514.1251598456874 like that.
I want to insert as 2514.125
How can i reduce the decimal points.
LUPREC settings does not work with this.
