haisagiviz Posted September 25, 2019 Posted September 25, 2019 Hi everyone, Please help me a lisp to search and replace Dimension text override (like as Lee Mac's lisp but just run in background, not with DCL). E.g: Replace all of dimensions text from <mesurevalue> to <> (in background) Thank you so much. HAI Quote
Lee Mac Posted September 26, 2019 Posted September 26, 2019 If you're merely looking to remove any & all dimension text overrides, you can try the following: (defun c:removedimtextoverride ( / i s x ) (if (setq s (ssget "_X" '((0 . "*DIMENSION") (1 . "*?*")))) (repeat (setq i (sslength s)) (setq i (1- i) x (entget (ssname s i)) ) (entmod (subst '(1 . "") (assoc 1 x) x)) ) (princ "\nNo dimension measurements have been overridden.") ) (princ) ) 1 Quote
haisagiviz Posted September 30, 2019 Author Posted September 30, 2019 Thank @Lee Mac for your help. But actually I need to search and replace just apply to Dimension element only. Is there any method to do that? Quote
