Check if a custom key exist
MastroLube
Hi there!
I've a problem managing custom keys. I'm not able to check if they exist. If I query a custom key that doens't exist i got an error and it exit the lisp.
What's the right command to accomplish that?
(setq App (vlax-Get-Acad-Object)
Doc (vla-Get-ActiveDocument App)
summaryInfo (vla-Get-SummaryInfo Doc)
(IF (/ nil (vla-GetCustomByKey summaryInfo "n_project" 'Value))
76879880_2019-09-1711_24_32-9655_Sottotetto.dwgProperties.png.69b1ec01b1c1aab79d5cd5c92b9956b2.png
Currently I'm just looking for the number of elements and if they are less then 3 i create them all.. It's time to fix that :)
(IF (< (vla-NumCustomInfo summaryInfo) 3)
    (crea_customkeys summaryInfo)
Thanks for the help!
Dennis
Hi,
The forward slash ( / ) is a dividing symbol and despite of that, you don't need to check if a variable is not equal to nil to know that it has a value so just remove the (/= ....  nil)
Thanks for the advice! It was a misspelling of "/="  😅
anyway i get NIL and not his value
Command: (vla-GetCustomByKey summaryInfo "n_project" 'Value)
nil
It should return "IT.19.9655". Am I missing something?
Thanks!
Edited by MastroLube
Yeah me also get nil value although that it has a value as per your posted example. !
That's really odd. 😕
1 hour ago, MastroLube said:
Hi there!
Dennis
(SetCustomDwgProp "Pages" "1")
Will add only if necessary then set the Custom Property "n_project" to "IT.19.9655" using the following code.
(defun getCustomDwgProp	(key / app doc dwgprops try val)
  (vl-load-com)
	DwgProps (vla-Get-SummaryInfo Doc)
  (cond
    ((vl-catch-all-error-p
       (setq try (vl-catch-all-apply
		   'vla-GetCustomByKey
		   (list DwgProps key 'val)
     (setq val nil)
  val
(defun SetCustomDwgProp	(key value / App Doc DwgProps)
  (vl-load-com)
  (if (getCustomDwgProp key)
    (vla-SetCustomByKey DwgProps key value)
    (vla-AddCustomInfo DwgProps key value)
  • Thanks 3
