Cong Van Posted September 13, 2019 Share Posted September 13, 2019 - I have an excel file with the content of column A being Vietnamese, column B being English. - In the Autocad file, there are contents of Vietnamese or English text - Using Autolisp code (TTA to add English content, TTV to add Vietnamese content), scan to select the object, select the Excel file containing the content, Autolisp will add the corresponding content under the sample text with appropriate spacing. Thank you for your interest and support for my request! I have cad and excel file attached test.xls test.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 13, 2019 Share Posted September 13, 2019 So its a look up that your after write in English then find the Vietnamese version and add ? Or other way on language. This has been answered before, do a google. For me write a csv file, Viet,eng much easier to get at with lisp. Then lisp is search replace or add to ? 1 Quote Link to comment Share on other sites More sharing options...
Cong Van Posted September 14, 2019 Author Share Posted September 14, 2019 Thank you Bigal I will try to follow your ideas. Looking forward to the next support. Quote Link to comment Share on other sites More sharing options...
