jim78b Posted September 11, 2019 Posted September 11, 2019 i read all posts in the web but i can 't change dimension colors in my solidworks 2016; i create a new layer called dim with red color then i go in document options anch assign to linear dimension the layer. than i set per standar as default layer but the dimensions are grey or black i active the color view! Quote
