Sooshiant Posted September 7, 2019 Posted September 7, 2019 We can turn blipmode off by .BLIPMODE command in AutoCad 2019, but there is a bug which turns it on again and again by it self so that I should turn it off each time the way it makes me mad. Is there any way to turn off blipmode forever? Quote
Cad64 Posted September 7, 2019 Posted September 7, 2019 This is the first time I've heard anyone mention an issue with Blipmode turning on by itself, so I don't think it's a bug. Are you using any custom lisp routines that may be turning it on? This seems like a more likely scenario. 1 Quote
Sooshiant Posted September 7, 2019 Author Posted September 7, 2019 (edited) Yes, there is lisp I use to type Persian in AutuCad. When I run that lisp blipmode turn on automatically, but in previous versions of AutoCad I didn't have this problem. This problem just occurred when I updated to 2019 version. Edited September 7, 2019 by Sooshiant Quote
Cad64 Posted September 7, 2019 Posted September 7, 2019 5 hours ago, Sooshiant said: Yes, there is lisp I use to type Persian in AutuCad. When I run that lisp blipmode turn on automatically, but in previous versions of AutoCad I didn't have this problem. This problem just occurred when I updated to 2019 version. You should start a new thread in the lisp section, post your lisp file and ask someone to look at it and see if they can fix the problem. 1 Quote
ReMark Posted September 8, 2019 Posted September 8, 2019 If the program ends in .lsp can you upload a copy of the lisp program here? Quote
