dirtyacc Posted September 2, 2019 Posted September 2, 2019 (edited) when the block reference contain xref inside the block, it will fail and throw error. i think it try to get the external reference boundingbox is culprit. lee, I wanted to leave a measage in your site, but i never make the message sent success. Edited September 2, 2019 by dirtyacc Quote
Lee Mac Posted September 2, 2019 Posted September 2, 2019 With limited testing I cannot seem to reproduce an error - could you please upload a sample drawing? Quote
dirtyacc Posted September 3, 2019 Author Posted September 3, 2019 Drawing 1 has a block which contian only one recentgle. Drawing 2 have a block contain a circle and an external reference "Drawing 1.dwg" When try to justifiy the block in Drawing 2 will fail, no matter the xref is resloved or not. Desktop.zipFetching info... Quote
dirtyacc Posted September 3, 2019 Author Posted September 3, 2019 On 9/2/2019 at 9:59 PM, Lee Mac said: With limited testing I cannot seem to reproduce an error - could you please upload a sample drawing? Expand Thannks for the reply. I've upload a simple example to reproduce the problem. Quote
dirtyacc Posted September 8, 2019 Author Posted September 8, 2019 On 9/2/2019 at 9:59 PM, Lee Mac said: With limited testing I cannot seem to reproduce an error - could you please upload a sample drawing? Expand It's just me or do you reproduce the problem? I like the UI of JBP script, now I use your CBPR/CBP to change block base point when block contain xref. Quote
Lee Mac Posted September 8, 2019 Posted September 8, 2019 (edited) On 9/8/2019 at 5:58 AM, dirtyacc said: It's just me or do you reproduce the problem? I like the UI of JBP script, now I use your CBPR/CBP to change block base point when block contain xref. Expand Please the updated Version 1.1 - the issue was due to the nested block within the nested xref. Edited September 8, 2019 by Lee Mac Quote
dirtyacc Posted September 10, 2019 Author Posted September 10, 2019 (edited) On 9/8/2019 at 1:07 PM, Lee Mac said: Please the updated Version 1.1 - the issue was due to the nested block within the nested xref. Expand thanks for the update, it works, when the xref is resolved, but will throw error when the xref is unresolved.... We used a xref for the handwriting signature in a relatived path, so it's fairly coomon send and recieve DWG with unresolved xref...As I understand, an xref position is only about it's insertion point, it should able to change the position of the nested xref even without know it's actual size in order to retain the entities relative position, right? Edited September 10, 2019 by dirtyacc Quote
