Guest Posted September 1, 2019 Posted September 1, 2019 Dear all, I'm looking for a simple lisp (probably vlisp) routine that can select all leaders of the same type (e.g dot). In other words, i only want to select the dot leaders of all my leaders in the drawing file. Should look something like this: (ssget "x" ("leader")) and ('leadertype 3) Thanks Quote
BIGAL Posted September 3, 2019 Posted September 3, 2019 Do you mean leader style dot? (setq ss (ssget "x" (list (cons 0 "leader")(cons 3 "Dot")))) Quote
Guest Posted September 3, 2019 Posted September 3, 2019 On 9/3/2019 at 2:54 AM, BIGAL said: Do you mean leader style dot? (setq ss (ssget "x" (list (cons 0 "leader")(cons 3 "Dot")))) I tried this, it gave me nil. If you can make what you have written work, I would definitely use it. Thanks for trying. I tried another method and it worked: (vl-load-com) (defun c:ABC () (setq myss (ssget "x" '((0 . "LEADER")))) (setq myssArrow (ssadd)) (setq myssDot (ssadd)) (vlax-for object (setq ActiveSelSet (vla-get-ActiveSelectionSet (vla-get-ActiveDocument (vlax-get-Acad-Object)))) (setq myArrowType (vlax-get-property object 'arrowheadtype)) (if (eq myArrowType 0) (progn (princ "ARROW") (vlax-put-property object 'ArrowHeadSize 1.25) (setq myssArrow (ssadd (vlax-vla-object->ename object) myssArrow)) ) ) (if (eq myArrowType 3) (progn (princ "DOT") (vlax-put-property object 'ArrowHeadSize 0.6) (setq myssDot (ssadd (vlax-vla-object->ename object) myssDot)) ) ) );vlax-for (princ) ) Quote
BIGAL Posted September 4, 2019 Posted September 4, 2019 (edited) Maybe a bit simpler. ; arrow closed fill is 0 Dot is 3 look at properties and count or run dumpit.lsp pick leader (defun test ( / myss obj ahead) (setq myss (ssget "x" '((0 . "LEADER")))) (repeat (setq x (sslength myss)) (setq obj (vlax-ename->vla-object (ssname myss (setq x (1- x))))) (setq ahead (vla-get-arrowheadtype obj)) (cond ((= ahead 3)(vla-put-arrowheadsize obj 1.25)) ((= ahead 0)(vla-put-arrowheadsize obj 0.6)) ) ) ) (test) Edited September 4, 2019 by BIGAL Quote
Guest Posted September 4, 2019 Posted September 4, 2019 On 9/4/2019 at 7:59 AM, BIGAL said: Maybe a bit simpler. ; arrow closed fill is 0 Dot is 3 look at properties and count or run dumpit.lsp pick leader (defun test ( / myss obj ahead) (setq myss (ssget "x" '((0 . "LEADER")))) (repeat (setq x (sslength myss)) (setq obj (vlax-ename->vla-object (ssname myss (setq x (1- x))))) (setq ahead (vla-get-arrowheadtype obj)) (cond ((= ahead 3)(vla-put-arrowheadsize obj 1.25)) ((= ahead 0)(vla-put-arrowheadsize obj 0.6)) ) ) ) (test) Expand Works well. Thanks, I appreciate the help. Quote
