Autocad lt 2020 Crashes and Crashed
I have tried using Autocad LT 2020.1 and it seems that after a windows update, Autocadlt 2020 is crashing while working on a drawing. Perhaps a regen, or a hatch pattern will cause ACLT2020 to immediately crash. I did not have problems before the windows update or the 2020.1 update.
Anyone else seen this behavior or experiencing crashes?
Nope, I use LT 2020.1 and haven't been having any problems, if this is happening regularly then maybe a setting it back to defaults could help (just check your customizations are saved first). Do you have all the latest drivers for your computer graphics can be a problem for some, you could try turning off hardware accelaration.
Might help to know your computer and OS details.
  • 2 weeks later...
There was a 2020 update that helped my crashing.... on the Autodesk site
