hxbtdtna Posted August 28, 2019 Posted August 28, 2019 (edited) Dear all, I'm searching a method to select(filter) dimensions with dim roundoff different from origin. I found that in this forum had a solution but the lisp did not work: https://www.cadtutor.net/forum/topic/46937-dim-roundoff-selection-lisp/ Please help me to solve this lisp. DIMS_ROUNDOFF HIGHLIGHT_1.lsp Edited August 28, 2019 by hxbtdtna Quote
Emmanuel Delay Posted August 28, 2019 Posted August 28, 2019 I don't get it. What do you mean " roundoff different from origin" ? Do you mean dimensions where one of the points is not 0,0 ? Quote
Roy_043 Posted August 28, 2019 Posted August 28, 2019 I suppose 'different from origin' means 'different from the default (dimstyle)'. So I think the OP is trying to select dimensions that have an override for the DIMRND setting (and/or the DIMDEC setting?). An example DWG may help to clarify things. Quote
Lee Mac Posted August 28, 2019 Posted August 28, 2019 The following will select all dimensions with an overidden Dim Roundoff (DIMRND) setting: (defun c:dimrndsel ( / e i s ) (if (setq s (ssget "_X" '((0 . "*DIMENSION") (-3 ("ACAD"))))) (repeat (setq i (sslength s)) (setq i (1- i) e (ssname s i) ) (if (not (member '(1070 . 45) (cdadr (assoc -3 (entget e '("ACAD")))))) (ssdel e s) ) ) ) (sssetfirst nil s) (princ) ) Quote
hxbtdtna Posted August 29, 2019 Author Posted August 29, 2019 Thank you very much Lee Mac. It's all that i need. Quote
