alark Posted August 28, 2019 Posted August 28, 2019 Hi. I am drawing this object 3d model in my unregistered autocad 2k18 version. The object is having smooth lines in my system. When the same file is opened for cnc cutting, the borders are showing zig zag. What should I do to overcome this problem? I think the curve I used for this was polyline that was changed to fit. Quote
Cad64 Posted August 28, 2019 Posted August 28, 2019 You will have better luck if you use lines and arcs. CNC machines typically don't like any sort of spline objects. Quote
