veteranus Posted August 26, 2019 Share Posted August 26, 2019 Hi, Can I draw a straight polyline (with my selected layer) into multiple rectangles based on the long edge? For example: http://prntscr.com/oxmpjh Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 26, 2019 Share Posted August 26, 2019 Are the rectangle lines or polylines? A sample drawing always helps (for me saved as 2010). 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 27, 2019 Share Posted August 27, 2019 If lines can use Join command 1st for this request simpler for user to do join 1st and only write code for plines. Edit for desired layer name. (defun test (/ pt1 pt2 pt3 pt4 d1 d2 ss x1 y1 x2 y2 oldsnap oldlay) (setq oldsnap (getvar 'osmode)) (setq oldlay (getvar 'clayer)) ;(setvar 'clayer your layername) change to your layer name (setq lay (cdr (assoc 8 (entget (car (entsel "pick a pline")))))) (setq ss (ssget (list (cons 0 "lwpolyline") (cons 8 lay)))) (setvar 'osmode 0) (repeat (setq x (sslength ss)) (setq co-ord '()) (setq plent (ssname ss (setq x (1- x)))) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget plent)))) (if (= (length co-ord) 4) (progn (setq pt1 (nth 0 co-ord)) (setq pt2 (nth 1 co-ord)) (setq pt3 (nth 2 co-ord)) (setq pt4 (nth 3 co-ord)) (setq d1 (distance pt1 pt2)) (setq d2 (distance pt2 pt3)) (If (< d1 d2) (progn (setq x1 (/ (+ (car pt1) (car pt2)) 2.0)) (setq y1 (/ (+ (cadr pt1) (cadr pt2)) 2.0)) (setq x2 (/ (+ (car pt3) (car pt4)) 2.0)) (setq y2 (/ (+ (cadr pt3) (cadr pt4)) 2.0)) (command "line" (list x1 y1) (list x2 y2) "") ) (progn (setq x1 (/ (+ (car pt2) (car pt3)) 2.0)) (setq y1 (/ (+ (cadr pt2) (cadr pt3)) 2.0)) (setq x2 (/ (+ (car pt1) (car pt4)) 2.0)) (setq y2 (/ (+ (cadr pt1) (cadr pt4)) 2.0)) (command "line" (list x1 y1) (list x2 y2) "") ) ) ) (alert " Object has less or more than 4 sides\n \n So skipped") ) ) (setvar 'osmode oldsnap) (setvar 'clayer oldlay) (princ) ) (test) 2 Quote Link to comment Share on other sites More sharing options...
veteranus Posted August 27, 2019 Author Share Posted August 27, 2019 Hi again and sorry for delay, Dear dlanorh these are polylines. Dear BIGAL your lisp code is working like charm. Thank you guys both and have a nice day. Regards. Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 27, 2019 Share Posted August 27, 2019 Here's another way to do it. Does not work on squares. (defun c:foo (/ pts s) ;; RJP » 2019-08-27 (cond ((setq s (ssget '((0 . "lwpolyline") (90 . 4)))) (foreach pl (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq pts (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget pl)))) (setq pts (mapcar '(lambda (r j) (list (distance r j) (mapcar '/ (mapcar '+ r j) '(2 2 2)))) pts (append (cdr pts) (list (car pts))) ) ) (setq pts (vl-sort pts '(lambda (r j) (< (car r) (car j))))) (entmakex (list '(0 . "line") '(8 . "line") '(62 . 1) (cons 10 (cadr (car pts))) (cons 11 (cadr (cadr pts))) ) ) ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 27, 2019 Share Posted August 27, 2019 Glad to help like ronjonp a square may not give correct answer. Same with some odd sized shapes see image above as I only do a simple compare. 1 Quote Link to comment Share on other sites More sharing options...
veteranus Posted August 28, 2019 Author Share Posted August 28, 2019 14 hours ago, ronjonp said: Here's another way to do it. Does not work on squares. (defun c:foo (/ pts s) ;; RJP » 2019-08-27 (cond ((setq s (ssget '((0 . "lwpolyline") (90 . 4)))) (foreach pl (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq pts (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget pl)))) (setq pts (mapcar '(lambda (r j) (list (distance r j) (mapcar '/ (mapcar '+ r j) '(2 2 2)))) pts (append (cdr pts) (list (car pts))) ) ) (setq pts (vl-sort pts '(lambda (r j) (< (car r) (car j))))) (entmakex (list '(0 . "line") '(8 . "line") '(62 . 1) (cons 10 (cadr (car pts))) (cons 11 (cadr (cadr pts))) ) ) ) ) ) (princ) ) Hi, The code works but automatically opens the "line" layer and draws the middle line with it. Is it possible to draw with the selected layer? Quote Link to comment Share on other sites More sharing options...
ronjonp Posted August 28, 2019 Share Posted August 28, 2019 (edited) Sure. Change this: '(8 . "line") To this: (assoc 8 pl) Edited August 28, 2019 by ronjonp 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 30, 2019 Share Posted August 30, 2019 Your screen grab shows new lines as a different colour hence ronjonp code is correct using a different layer it does not have to be "Lines" or in mine ;(setvar 'clayer yourlayername) change to your layer name If you want same layer and a different color and line type need to advise can be done in both code provided. ronjonp entmake mine chprop probably. Quote Link to comment Share on other sites More sharing options...
mdivy10 Posted March 31, 2023 Share Posted March 31, 2023 Hello, this is a great LISP. Is there a way you could rewrite to create the red centerline with a 3D polyline instead of polyline? I am looking to replace a 3D polyline rectangle (white) with a single 3D polyline down the center (red) that will have Z1 be the north value and Z2 be the south value. Thanks. Quote Link to comment Share on other sites More sharing options...
