jim78b Posted August 24, 2019 Posted August 24, 2019 i have this macro and not understand why if i set lweight bylayer after launch my macro the lweight display on instead remain as should be :OFF ^C^C_clayer 0;^C^C_color BYBLOCK;^C^C-linetype;S BYLAYER;^C^C_lweight BYLAYER; Quote
steven-g Posted August 24, 2019 Posted August 24, 2019 Looks like running the lweight command automatically turns on the display, but you can turn it off at the end of your macro by adding this to the end. _lwdisplay;off; Quote
jim78b Posted August 24, 2019 Author Posted August 24, 2019 Yes i know but if i draw with lweight on i don't want it off .is normal that lweight command enable lweight display ? Quote
steven-g Posted August 24, 2019 Posted August 24, 2019 I never use it but, it does appear to be. Looks like something you just need to learn to live with, in a macro the lweight command will automatically turn it on, I suppose you could add in a diesel expression at the start of your macro to reaad the variable "lwdisplay" at the start of the macro and then reset it at the end so that the value remains the same. Quote
jim78b Posted August 24, 2019 Author Posted August 24, 2019 (edited) 28 minutes ago, steven-g said: I never use it but, it does appear to be. Looks like something you just need to learn to live with, in a macro the lweight command will automatically turn it on, I suppose you could add in a diesel expression at the start of your macro to reaad the variable "lwdisplay" at the start of the macro and then reset it at the end so that the value remains the same. Thanks i want only know if was normal and if i used the macro command right .i can remove lweight and not use if someone don't know why lweight active the display of lines weight Edited August 24, 2019 by jim78b Quote
steven-g Posted August 24, 2019 Posted August 24, 2019 Yes it certainly looks normal, I can see no problems in your macro. Quote
tombu Posted August 24, 2019 Posted August 24, 2019 8 hours ago, jim78b said: i have this macro and not understand why if i set lweight bylayer after launch my macro the lweight display on instead remain as should be :OFF ^C^C_clayer 0;^C^C_color BYBLOCK;^C^C-linetype;S BYLAYER;^C^C_lweight BYLAYER; To modify layer 0 use "^C^C_-LAYER Make 0" and set whatever properties you want for layer 0 while you're in there. Try using CELWEIGHT to set current lineweight. Gotta ask, why set color BYBLOCK, and everything else BYLAYER? I generally always use BYBLOCK for block entities and BYLAYER for everything else. Quote
jim78b Posted August 24, 2019 Author Posted August 24, 2019 (edited) Thank you today i am in Montain. Monday i will try ...have a nice day Edited August 24, 2019 by jim78b Quote
jim78b Posted August 24, 2019 Author Posted August 24, 2019 I use byblock because i use a lot blocks and need often change color Quote
jim78b Posted August 26, 2019 Author Posted August 26, 2019 On 8/24/2019 at 12:12 PM, steven-g said: Yes it certainly looks normal, I can see no problems in your macro. even with CELWEIGHT autocad turn on the lwdisplay Quote
jim78b Posted August 26, 2019 Author Posted August 26, 2019 if i use -layer lw not permit to choose bylayer only thicknes Quote
jim78b Posted August 26, 2019 Author Posted August 26, 2019 ok work with cel weight ! thanks to all! 1 Quote
steven-g Posted August 26, 2019 Posted August 26, 2019 Well done, It can be frustrating at times trying to get things to work as you hope, and macro's often are limited in their use. And finding just that right setting or option/variable is often a long drawn out process. So it's good to see that you got there and it's great that you let us know (and pretty quick too). Quote
tombu Posted August 26, 2019 Posted August 26, 2019 4 hours ago, jim78b said: if i use -layer lw not permit to choose bylayer only thicknes You cannot set any layer property to bylayer! With -layer you can set lineweight to Default, same as you would with the Layer Palette. I'd still recommend using byblock for all the properties of block entities and bylayer for everything else. Quote
jim78b Posted August 26, 2019 Author Posted August 26, 2019 27 minutes ago, tombu said: You cannot set any layer property to bylayer! With -layer you can set lineweight to Default, same as you would with the Layer Palette. I'd still recommend using byblock for all the properties of block entities and bylayer for everything else. ok thanks you very much for your help! have a nice day Quote
