pmadhwal7 Posted August 19, 2019 Share Posted August 19, 2019 Dear all, i want an lisp which will put automatic dimension on perpendicular to polyline from an object/block here i am attached a sample dwg please help me ... ALIGN DIMEN.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 19, 2019 Share Posted August 19, 2019 (edited) I may be wrong but I think you can do it using dim and base command. Not a dim style that I use very often. Edited August 19, 2019 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 19, 2019 Author Share Posted August 19, 2019 12 minutes ago, BIGAL said: I may be wrong but I think you can do it using dim and base command. Not a dim style that I use very often. can't get ur words sir....please explain Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 23, 2019 Author Share Posted August 23, 2019 it seems nobody want to help me.... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 24, 2019 Share Posted August 24, 2019 Did you try DIM BASE Must have 1 dim existing, dim style needed as well. 1 Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 26, 2019 Author Share Posted August 26, 2019 On 8/24/2019 at 6:22 AM, BIGAL said: Did you try DIM BASE Must have 1 dim existing, dim style needed as well. sir please tell me what is dim base?? Quote Link to comment Share on other sites More sharing options...
Ish Posted August 26, 2019 Share Posted August 26, 2019 Command: DIMBASE DIMBASELINE but first you must have or draw a dimension than dimbase will work continuously. Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 26, 2019 Author Share Posted August 26, 2019 no sir this command is not helpful for me please chek my dwg file Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted August 30, 2019 Author Share Posted August 30, 2019 sir can you write any lsp for this??? Quote Link to comment Share on other sites More sharing options...
asos2000 Posted September 2, 2019 Share Posted September 2, 2019 I coded the attached for roads dimension Extract attached Copy extracted folder to C:\ In this folder a cad file and lisp open CAD file and modify the blocks as your requirements Load this lisp and have fun RoadDimension.zip Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted September 3, 2019 Author Share Posted September 3, 2019 18 hours ago, asos2000 said: I coded the attached for roads dimension Extract attached Copy extracted folder to C:\ In this folder a cad file and lisp open CAD file and modify the blocks as your requirements Load this lisp and have fun RoadDimension.zip 965.16 kB · 2 downloads Sir can you post any video help for this....i am unable to use this lsp Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted September 3, 2019 Author Share Posted September 3, 2019 (edited) this error message coming ** Error: bad argument value: AcDbCurve 85 **AutoCAD variable setting rejected: "cmdecho" nil Edited September 3, 2019 by pmadhwal7 Quote Link to comment Share on other sites More sharing options...
asos2000 Posted September 4, 2019 Share Posted September 4, 2019 https://drive.google.com/open?id=1aOEgqkJwL1Hsb6bK-qpJznJACjnUEhya Quote Link to comment Share on other sites More sharing options...
pmadhwal7 Posted September 12, 2019 Author Share Posted September 12, 2019 On 9/4/2019 at 6:02 PM, asos2000 said: https://drive.google.com/open?id=1aOEgqkJwL1Hsb6bK-qpJznJACjnUEhya still unable to use...sir Quote Link to comment Share on other sites More sharing options...
