Talha Kaleem Posted August 18, 2019 Posted August 18, 2019 Hello Friends. How are you? Friends, i have a problem. I have two splines located at same elevation with their ends connected. Now, i want to join these two into one. I have tried both join and pedit commands but none of them are working. I have attached CAD file and I am using 2013 version of AutoCAD. Looking forward to hear from you. Thank You Not_joining.dwgFetching info... Quote
Cad64 Posted August 18, 2019 Posted August 18, 2019 I checked your drawing and although it looks like the splines are snapped together and at the same elevation, apparently they are not. I grabbed one of the splines by the endpoint and snapped it to the other spline. Then I ran the JOIN command and they became one. Give it a try. 1 Quote
Talha Kaleem Posted August 19, 2019 Author Posted August 19, 2019 Cad 64. It worked the way you did it. Good work. Thank you very much Quote
Talha Kaleem Posted August 21, 2019 Author Posted August 21, 2019 Hello. CAD64 today i have came with the same problem but different figure. Again these segments are not joining. there are 5 segments and i want to join all of them to make one. I tried and snapped their ends on one another but problem persits. Please have a look at it. Thank You. not_joining.dwgFetching info... Quote
Cad64 Posted August 21, 2019 Posted August 21, 2019 On 8/21/2019 at 1:20 PM, Talha Kaleem said: Hello. CAD64 today i have came with the same problem but different figure. Again these segments are not joining. there are 5 segments and i want to join all of them to make one. I tried and snapped their ends on one another but problem persits. Please have a look at it. Expand It works fine for me. I joined all the segments with no problem. I'm using 2018 though. Not sure if that makes a difference. Quote
Talha Kaleem Posted August 21, 2019 Author Posted August 21, 2019 Cad64 from where can i download AutoCAD 2018 for free? Quote
Cad64 Posted August 21, 2019 Posted August 21, 2019 On 8/21/2019 at 2:05 PM, Talha Kaleem said: Cad64 from where can i download AutoCAD 2018 for free? Expand You can't download 2018 anymore. It's a few years old. But you can download the trial version of 2020 here: https://www.autodesk.com/products/autocad/free-trial Quote
Talha Kaleem Posted August 21, 2019 Author Posted August 21, 2019 Cad64 i want full version of AutoCAD. I am already using a trial version. These expire after a month. If you have any suggestions where to get full version of it? Thank You. Quote
Cad64 Posted August 21, 2019 Posted August 21, 2019 On 8/21/2019 at 2:16 PM, Talha Kaleem said: Cad64 i want full version of AutoCAD. I am already using a trial version. These expire after a month. If you have any suggestions where to get full version of it? Expand We are not that kind of forum. If you're looking for illegal downloads, you will have to look elsewhere. If you can't afford the high cost of Autocad, there are cheaper alternatives. Follow the link below to find a list of low cost CAD programs. Quote
Cad64 Posted August 21, 2019 Posted August 21, 2019 I just took another look at your drawing and found that the PEDIT command doesn't work but the JOIN command does work. The JOIN command is much more forgiving and can work on different types of entities. So, if PEDIT fails, use JOIN. Quote
