I'm trying to apply an action to a button to insert a block, but I get an error exception in veval-str+ arx command unhandled
Can someone help me solve the problem?
subfunction and how am i applying the action
(defun Inblk ( name* tag1 tag2 )
  (if (not (tblsearch "BLOCK" name*))
    (command "_insert" name* pause "" "" "" tag1 tag2)
"        : butt { key = \"bt01\"; label = \"9.300\";  }"
(action_tile "bt01"  "(Inblk \"D_Poste\"\"9/300\" nil ) (done_dialog 1)")
You are trying to run a command ("_insert") inside a modal dialog.
Expand
it's a problem?
vla-SendCommand  it works ?
Edited by Anushka
  On 8/16/2019 at 7:33 PM, Anushka said:
it's a problem?
Expand
No. Nothing works unless the form is hidden as @rkmcswain alluded to above. The "form" is Modal. Nothing will work until it hidden or ended.
Are you collecting the exit state from the dialog, as you're using (done_dialog 1). I collect it by using (setq x_val (start_dialog))
Then change
to
(action_tile "bt01"  "(done_dialog 1)")
and after unloading the dialog
(cond ( (= x_val 1) (Inblk "D_Poste" "9/300" "")))
You cannot set an attribute 'TEXTSTRING value to nil, it will error so you send it the null string ""
If you are doing several block you can store the values in strings
eg
(action_tile "bt01"  "(progn (setq blk \"D_Poste\" t1 \"9/300\" t2 "") (done_dialog 1))")
Then
(cond ( (= x_val 1) (Inblk blk t1 t2)))
  • Thanks 1
  On 8/20/2019 at 11:57 AM, Anushka said:
@dlanorh Thank you it worked !!!
Expand
You're welcome.
  • 5 years later...
I had this issue and vla-SendCommand worked for me.
  ;; Function to rename a block withing a DCL
  ;; Call the function within the DCL:
  ;; (_renameBlock Oldname NewName)
  (defun _renameBlock (old new / actDoc)
    (if (tblobjname "BLOCK" new)
      (princ (strcat "\n\"" new "\" block aleady exists."))
    (if (and (tblobjname "BLOCK" old) (not (tblobjname "BLOCK" new)))
        (setq actDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
        (vla-SendCommand actDoc (strcat "-rename _B " old "\r" new "\r"))
Edited by 3dwannab
@Anushka & @3dwannab
You could always just use activex, which can run in the background with the DCL, since it does not use the command line:
(defun _RenameBlock (bn nn / bobj)
   (if
      (and
         (tblsearch "BLOCK" bn)
         (not (tblsearch "BLOCK" nn))
         (setq bobj (vla-item (vla-get-Blocks (vla-get-ActiveDocument (vlax-get-acad-object))) bn))
         (vla-put-name bobj nn)
Edited by pkenewell
  • Thanks 1
