sandiegophil Posted August 12, 2019 Share Posted August 12, 2019 Hello, I am having a issue with the dialog boxes. An example being, if I am creating sections lines, when I select by station range, the text in the popup window is fine but the check boxes are extremely small. Please let me know if you have seen this happen or if you have a solution. Thanks, Phil Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 13, 2019 Share Posted August 13, 2019 Computer details? Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted August 13, 2019 Author Share Posted August 13, 2019 HP zbook 17 g5, (2) hp pavilion 27g monitors attached through a hp hub Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 29, 2019 Share Posted August 29, 2019 (edited) Windows 10 has a screen % setting I know some forms on screen are not quite right and changing from %125 to 100% changes but I did change back and live with it,. Try this Screen, Display Settings on command line also the resolution setting. Edited August 29, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted August 29, 2019 Author Share Posted August 29, 2019 thank you for your suggestion, I appreciate the information. Quote Link to comment Share on other sites More sharing options...
