Zox Posted August 12, 2019 Share Posted August 12, 2019 Can someone recommend me some program for easy rendering? I've drew some 3d building in autocad and would need some program that can easily import autocad 3d models and render them. Quote Link to comment Share on other sites More sharing options...
f700es Posted August 12, 2019 Share Posted August 12, 2019 I'd try SimLab Composer, it has a free version that can be used for ANY purpose and can render to 1080 res with no watermark. https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx 1 Quote Link to comment Share on other sites More sharing options...
Zox Posted August 13, 2019 Author Share Posted August 13, 2019 (edited) OK thanks, interesting program. Although it doesn't load materials quite correctly and I have to set/ define them additionally (like glass) it's still very useful. Thanks again! Edited August 13, 2019 by Zox Quote Link to comment Share on other sites More sharing options...
f700es Posted August 13, 2019 Share Posted August 13, 2019 Really? Are you using it's glass material or using one brought in from AutoCAD? I've only used glass a few times but I only used it's materials. I also don't use dwg files in it, only SketchUp files for me. Quote Link to comment Share on other sites More sharing options...
Zox Posted August 13, 2019 Author Share Posted August 13, 2019 (edited) Yeah I use dwg files that?s why I said " I've drew some 3d building in autocad" but would it be better if I convert it to fbx? Edited August 13, 2019 by Zox Quote Link to comment Share on other sites More sharing options...
f700es Posted August 13, 2019 Share Posted August 13, 2019 LOL, yeah I got the part about using dwg files but you never said that you were using materials or textures in AutoCAD. I'd just try to use a glass material from SimLab and replace the one from AutoCAD. You'll probably need to download the extended material database for SimLab as well as the AutoCAD integration plugin if you haven't already. It seems to do OK. A few artifacts here and there but I only let it run for 5 minutes. The glass looks ok to me 1 Quote Link to comment Share on other sites More sharing options...
Zox Posted August 13, 2019 Author Share Posted August 13, 2019 (edited) Really, you got translucent glass? When I import dwg to SimLab and go to "Show Scene Materials" for every material in "Material Type" it is set to "Default" and then I have to change it to glass, metal... BTW is there a way for me to set from which corner I want it to render and then leave it to render like five pictures instead of me checking every few minutes until it finishes rendering and then set the new corner from which I want it to render? Edited August 13, 2019 by Zox Quote Link to comment Share on other sites More sharing options...
f700es Posted August 13, 2019 Share Posted August 13, 2019 Not sure about your rendering question. I have never tried that. I was under the impression that materials did not transfer well out of AutoCAD using dwg files. That was the reason I asked. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted August 13, 2019 Share Posted August 13, 2019 5 hours ago, f700es said: I was under the impression that materials did not transfer well out of AutoCAD using dwg files. That was the reason I asked. I'm pretty sure you're right about that. I used to bring CAD models into Studio Max for rendering and I always had to apply my materials in Max because they don't export out of Autocad. You could try exporting FBX out of Autocad, but I think you're going to have the same issue with materials. Quote Link to comment Share on other sites More sharing options...
Zox Posted August 14, 2019 Author Share Posted August 14, 2019 12 hours ago, Cad64 said: You could try exporting FBX out of Autocad, but I think you're going to have the same issue with materials. Even worse. When I export fbx out of autocad the materials don't even show up in SimLab. I also used to bring CAD models into Studio Max for rendering, but I didn't have problems with materials,. Still, I just wanted some simpler rendering program. Also when it comes to exporting materials out of autocad for some time I was using a program called "Iclone" for rendering 3d objects from autocad and I had no problem with importing them into Iclone (although I had to first convert it to fbx). But then I updated some programs that created problems with importing stuff from autocad. Quote Link to comment Share on other sites More sharing options...
f700es Posted August 14, 2019 Share Posted August 14, 2019 We'll AutoDesk has made going to Max from Acad easier than it used to be but Max is Not easy to use Until you get used to it. Quote Link to comment Share on other sites More sharing options...
acad_2k Posted December 29, 2019 Share Posted December 29, 2019 I too am looking for a simple rendering program for models created in AutoCAD. I use Autocad 2000 for furniture and built-ins but for architectural models, I use Architectural Desktop 2004. Looking at SimLab's site, it appears that it only imports .dwg files from AutoCAD 2019. Is that correct? Quote Link to comment Share on other sites More sharing options...
Cad64 Posted December 29, 2019 Share Posted December 29, 2019 9 hours ago, acad_2k said: Looking at SimLab's site, it appears that it only imports .dwg files from AutoCAD 2019. Is that correct? I'm fairly certain that means it can import dwg files up to 2019, meaning any newer file format would not import, but older file formats should be fine. The best thing to do is download the program and try it out. It's free so you don't have anything to lose. 1 Quote Link to comment Share on other sites More sharing options...
acad_2k Posted December 29, 2019 Share Posted December 29, 2019 Thanks, will give it a try Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted March 13, 2020 Share Posted March 13, 2020 Why not use AutoCAD for the render? Rendering some building shouldn't be an issue, and with enough dedication the results can be nearly as good as any other program. You could also try out [url=https://www.unrealengine.com/en-US/twinmotion]Twinmotion[/url] by Unrealreal Engine. It was free until recently. Quote Link to comment Share on other sites More sharing options...
f700es Posted March 13, 2020 Share Posted March 13, 2020 Yes, Twinmotion is very nice This took less than 5 minutes to set up and render. The arch was modeled and textured in SketchUp Pro. Quote Link to comment Share on other sites More sharing options...
velimir Posted April 18, 2020 Share Posted April 18, 2020 Guys, due to my laptop outstanding characteristics (4gb RAM 1.6 GHz, 1.6 GHz) can you recommend me some decent rendering software that my computer can support without problems? Even on autocad 2012, it starts to glitch on little more complicated 3D model... Quote Link to comment Share on other sites More sharing options...
Cad64 Posted April 18, 2020 Share Posted April 18, 2020 1 hour ago, velimir said: Guys, due to my laptop outstanding characteristics (4gb RAM 1.6 GHz, 1.6 GHz) can you recommend me some decent rendering software that my computer can support without problems? Even on autocad 2012, it starts to glitch on little more complicated 3D model... What are your full laptop specs? You mentioned you have 4GB RAM, which is not good. And, a 1.6 GHz processor? Also not good. Is it at least a dual core processor? If it's single core, I would say forget about rendering. You could try Simlab Composer, as recommended by f700es above. You can download the free lite version here: https://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx Quote Link to comment Share on other sites More sharing options...
velimir Posted April 19, 2020 Share Posted April 19, 2020 Thank you! Not good at all.. it is dual core, but it is a poor specs overall Quote Link to comment Share on other sites More sharing options...
f700es Posted April 19, 2020 Share Posted April 19, 2020 Find a good refurbished Dell desktop with at least a 4th gen i5 or higher. Then use an SSD hard drive, GTX 650 or higher and 16 gb of RAM. This what I have at home and it was under $400 USD. 1 Quote Link to comment Share on other sites More sharing options...
