Creating Toposurface through points file (CSV) [SOLVED]
Hi all,
I am trying to create a toposurface within Revit 2019 using a points file
What I have done is extracted the X Y and Value data from a 3d autocad topo, following the youtube guide below.
https://www.youtube.com/watch?v=l2nQwSfQ1YQ
I have the extracted info (below) which looks OK - similar form to the one in the youtube tutorial
It's once I select this file to import into Revit, that I get the prompt "Failed to open file"
Does anyone know what I might be doing wrong? The file is saved as CSV and the information only contains X Y and Z value.
SOLVED
There is 2 CSV files to save as, highlighted in image below.
The highlighted in red, does not work for me.
The green one (UTF-8) does work.
Not sure what the difference is between the two, but changing it has now solved my issue.
Thank in advance for any help
~Steve
Edited by Stevery
It may help to post the actual .dwg and the CSV.
Solved - see first post.
Edited by Stevery
  • 1 year later...
I had the same problem (failed to open). Created the Excel file, followed the X,Y,Z format, then saved. In Revit, I would Create Topo surface by Specifying the Points file.
When I downloaded sample files it worked, but when I opened the sample file and saved it to duplicate the format it didn't work in Revit. Then I realized the new file was open in Excel. Closed it and tried again in Revit. It worked.
After several attempts at different files and types I have found if the file is open in Excel it will not open in Revit. Having text (point identifiers) in column "A" and/or "E" has no effect on whether the file works.
Solution - Close the Excel file
