Romero Posted August 8, 2019 Posted August 8, 2019 Hello everyone. I am working with a code to copy object (s) and paste with rotation using the same base point as the axis of rotation. What I can't do is create a while cycle to be able to make multiple copies and rotate. I could only do it once. If someone helps me a little I would be very grateful. (defun c:cr (/ ss p1 p2 p3) (setq ss (ssget)) (command "copy" ss "" "0" "0") (setq p1 (getpoint "\n base Point: ")) (setq p2 (getpoint "\n destination point: ")) (command "move" ss "" p1 p2) (setq p3 (getpoint "\n reference point: ")) (command "rotate" ss "" p2 "R" "@" p3 pause) ) Quote
Lee Mac Posted August 8, 2019 Posted August 8, 2019 Perhaps something like this? (defun c:cr ( / p q r s ) (if (and (setq s (ssget "_:L")) (setq p (getpoint "\nSpecify base point: ")) (setq q (getpoint "\nSpecify destination point: " p)) (vl-cmdf "_.move" s "" "_non" p "_non" q) (setq r (getpoint "\nSpecify reference point: " q)) ) (while (vl-cmdf "_.rotate" s "" "_non" q "_C" "_R" "@" "_non" r "\\")) ) (princ) ) Quote
Romero Posted August 8, 2019 Author Posted August 8, 2019 (edited) 6 hours ago, Lee Mac said: Perhaps something like this? Hi @Lee Mac, thank you very much for your response. I really appreciate the help, but unfortunately it's not what I wanted. Maybe I didn't know how to explain myself well, and it's all my fault. I will try to explain it better to see if it is possible to help me: The problem is that I want to copy the same object, but I have to put several points: (destination point) 1.-I want to designate objects and be able to create multiple copies 2.-But when you copy the object, it can be rotated with a reference, which begins at the base point (So far I have no problem) 3.- without abandoning the command, copy the same object again, to create another copy and rotate it in the same way; For that, I would have to create a new point (destination point), but I can't solve it. 4.-repeat until canceled. Edited August 8, 2019 by Romero Quote
myloveflyer Posted August 9, 2019 Posted August 9, 2019 (edited) It is best to provide a drawing before processing and processing, so that everyone can help you. Edited August 9, 2019 by SLW210 Removed Quote Quote
