Ish Posted August 3, 2019 Share Posted August 3, 2019 (edited) DEAR SIR, I NEED A LISP TO GET OFFSET AND LEVEL OF POLYLINE. VERTICAL SCALE AND OFFSET MAY BE DIFFERENT. SOMETIME OFFSET REQUIRE 2,5,7.5 AND SAME VERTICAL SCALE 1:5, 1:10. IN ATTACH CAD FILE THERE IS 2 SITUATION NEED SOLUTION. **FOR MORE DETAIL SEE IMAGE. ROAD SK.dwg Edited August 3, 2019 by Ish MODIFY Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 3, 2019 Share Posted August 3, 2019 3 hours ago, Ish said: DEAR SIR, I NEED A LISP TO GET OFFSET AND LEVEL OF POLYLINE. VERTICAL SCALE AND OFFSET MAY BE DIFFERENT. SOMETIME OFFSET REQUIRE 2,5,7.5 AND SAME VERTICAL SCALE 1:5, 1:10. **FOR MORE DETAIL SEE IMAGE. It is impossible to test a lisp on an image. The image also doesn't tell me the text size, text style, polyline details or layer details etc... 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted August 3, 2019 Author Share Posted August 3, 2019 (edited) 1 hour ago, dlanorh said: It is impossible to test a lisp on an image. The image also doesn't tell me the text size, text style, polyline details or layer details etc... NOW IN CAD FILE YOU WILL SEE 2 SITUATION. ROAD SK.dwg Edited August 3, 2019 by Ish MODIFY Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 3, 2019 Share Posted August 3, 2019 OK, is the baseline (level datum) always arbitrary (lines Y coord is not the level)? Option 1 has a baseline in option 2 this is a closed polyline which makes intersection points more difficult. Will try to have a workable solution on monday. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted August 3, 2019 Author Share Posted August 3, 2019 33 minutes ago, dlanorh said: OK, is the baseline (level datum) always arbitrary (lines Y coord is not the level)? Option 1 has a baseline in option 2 this is a closed polyline which makes intersection points more difficult. Will try to have a workable solution on monday. YES BOSS the baseline (level datum) always arbitrary (lines Y coord is not the level) YES - Option 1 has a baseline option 2 this is a closed polyline - NO THAT IS ALSO baseline (level datum). I JUST DRAW A RECTANGLE SIR, ASSUME THAT IS ALSO BASE LINE. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 3, 2019 Share Posted August 3, 2019 Please look at attached drawing extract of situation 2. I am assuming it was just for reference and not correct? situation_2.dwg 1 Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 3, 2019 Share Posted August 3, 2019 6 hours ago, Ish said: YES BOSS the baseline (level datum) always arbitrary (lines Y coord is not the level) YES - Option 1 has a baseline option 2 this is a closed polyline - NO THAT IS ALSO baseline (level datum). I JUST DRAW A RECTANGLE SIR, ASSUME THAT IS ALSO BASE LINE. OK. Can I also switch the positions of offsets and levels so it is consistent with Option 1? 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 4, 2019 Share Posted August 4, 2019 (edited) This is my SRL.lsp and reports level from pick point, a good starting point. At moment only Rl is worked out and for vertical scale. The offset could be done using same method. You pick the datum text, enter vertical scale, a datum point and pt of interest it updates an existing text. SurfaceRL.lsp Edited August 4, 2019 by BIGAL 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted August 4, 2019 Author Share Posted August 4, 2019 8 hours ago, dlanorh said: Please look at attached drawing extract of situation 2. I am assuming it was just for reference and not correct? situation_2.dwg 73.31 kB · 0 downloads 100% correct sir, becoz i write roughly, but you make correct one. blue polyline was a 3dpoly i convert that, thats why z elevation is there. assume no z elevation. calculation must be based on datum and center line. thanks Quote Link to comment Share on other sites More sharing options...
Ish Posted August 4, 2019 Author Share Posted August 4, 2019 3 hours ago, BIGAL said: This is my SRL.lsp and reports level from pick point, a good starting point. At moment only Rl is worked out and for vertical scale. The offset could be done using same method. You pick the datum text, enter vertical scale, a datum point and pt of interest it updates an existing text. SurfaceRL.lsp 2.45 kB · 1 download CAN UPLOAD SOME IMAGE OR SCREEN SHOT, HOW TO USE THIS LISP , Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 4, 2019 Share Posted August 4, 2019 (edited) The program I wrote is used where you need a RL of a point based on a datum level it updates a existing text. Its about the method of how to do. How are you making the pline, datum, and text rectang ? Why would you not just add to that procedure. As I have said before purchase a commercial product it will do everything you want rather than the repeated questions of the next thing you want for free, hopefully your getting paid for this work. I am happy to do it but will have a fee. I am an independent contractor I had to buy my CAD software if I wanted to even offer free stuff here. Edited August 4, 2019 by BIGAL Quote Link to comment Share on other sites More sharing options...
Ish Posted August 8, 2019 Author Share Posted August 8, 2019 On 8/3/2019 at 11:14 PM, dlanorh said: OK. Can I also switch the positions of offsets and levels so it is consistent with Option 1? hello sir Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 8, 2019 Share Posted August 8, 2019 Sorry, very busy at the moment work wise. I should have something soon, just trying to iron out a few bugs. Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 12, 2019 Share Posted August 12, 2019 OK. Apologies for the time it has taken, but I had a "rush" job to complete that took up most of my time this past week. Attached is the Lisp for Option 1, along with a question for option 2 which I've labelled as "3". The drawing contains the maximum detail needed for the section, as the rest will be added by the lisp. The polyline will be automatically converted to run from left to right. The datum line will be converted from a polyline to a line (if required) and again set to run left to right. I needed it to do this to simplify the offseting. This produces the two "SOLUTIONS" with the given offsets. The 0.0 and 10.0 (or end of polyline) are added automatically so don't have to be entered. If you don't require all this let me know. Command to run (once loaded) is ODL. You will be asked for the vertical exaggeration. Default is 1 (1:1). If the exaggeration is 1:5 you only need to enter 5 You will be asked to select the polyline, then to select the Datum Line, followed by the Datum Line Level (default 0.000), and finally the offset distances (default 0.000). As mentioned above the lisp knows the 0.000 offset (start of polyline) and the end of polyline offset; these are added automatically, so you only need to enter the intermediate ones. This is all collected in a while loop and the offset distances are added to a list. Once all the intermediate offsets are added return the default (0.000) to exit the loop and produce the solution. I will attempt to added Solution 2 to this once I know all the requirements. ROAD-SK-TEST.dwg ODL.lsp 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted August 14, 2019 Author Share Posted August 14, 2019 On 8/12/2019 at 9:40 PM, dlanorh said: OK. Apologies for the time it has taken, but I had a "rush" job to complete that took up most of my time this past week. Attached is the Lisp for Option 1, along with a question for option 2 which I've labelled as "3". The drawing contains the maximum detail needed for the section, as the rest will be added by the lisp. The polyline will be automatically converted to run from left to right. The datum line will be converted from a polyline to a line (if required) and again set to run left to right. I needed it to do this to simplify the offseting. This produces the two "SOLUTIONS" with the given offsets. The 0.0 and 10.0 (or end of polyline) are added automatically so don't have to be entered. If you don't require all this let me know. Command to run (once loaded) is ODL. You will be asked for the vertical exaggeration. Default is 1 (1:1). If the exaggeration is 1:5 you only need to enter 5 You will be asked to select the polyline, then to select the Datum Line, followed by the Datum Line Level (default 0.000), and finally the offset distances (default 0.000). As mentioned above the lisp knows the 0.000 offset (start of polyline) and the end of polyline offset; these are added automatically, so you only need to enter the intermediate ones. This is all collected in a while loop and the offset distances are added to a list. Once all the intermediate offsets are added return the default (0.000) to exit the loop and produce the solution. I will attempt to added Solution 2 to this once I know all the requirements. ROAD-SK-TEST.dwg 71.95 kB · 1 download ODL.lsp 8.31 kB · 1 download thanks for support sir it solve my problem 70% i have some suggestion for you plz consider. see below =============================================================================================================== Situation -1 1. Enter Vertical Scale Exaggeration (eg 1:5 = 5) <1> : Here we have 2 Vertical Scale 1:1 & 1:5 please add 1:10 also. 2. Enter Datum Line Level <0.000> : Here add pick text option Pick Datum Level Or Type Datum Level <0.000>: 3. Enter First Offset Distance or (0.0 to Exit) <0.000> : Here don’t make fix offset 0.0 (by default is ok), may be some case I have first offset 10 or other value. Here please add next line for fix interval Enter the Interval (0.0 to Exit) <0.000> : Example: Enter First Offset Distance or (0.0 to Exit) <0.000> : 10 Enter the Interval (0.0 to Exit) <0.000> :2 If I type interval 2 automatically upto end of pline Offset show 12, 14, 16, 18, 20 …. ***************************************************************************************************************************** Situation -2 Cross section I need value at pline vertex. As you show in solution that is perfect for me. I need exactly like that. waiting for your good reply. Thanks ----------------------------------- Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 14, 2019 Share Posted August 14, 2019 6 hours ago, Ish said: 1. Enter Vertical Scale Exaggeration (eg 1:5 = 5) <1> : Here we have 2 Vertical Scale 1:1 & 1:5 please add 1:10 also. This is not a selection. If the vertical exageration is 1:5 you enter 5 if it is 1:10 you enter 10. The default is 1:1 <1>. If you want this as selection list thats not a problem. There is no problem with the rest. 1 Quote Link to comment Share on other sites More sharing options...
Ish Posted August 14, 2019 Author Share Posted August 14, 2019 (edited) 27 minutes ago, dlanorh said: This is not a selection. If the vertical exageration is 1:5 you enter 5 if it is 1:10 you enter 10. The default is 1:1 <1>. If you want this as selection list thats not a problem. There is no problem with the rest. no sir , I dont want selection list . I thought this is for 1:1 and 1:5 ONLY, NOW 1 CHECK . THIS IS FOR ANY VERTICAL SCALE, GOOD. NO. 1 whAT ABOUT FIX INTERVAL: (POINT NO 3.) AND CROSS SECTION ** PLZ ADD A CODE FOR LAYER . OFFSET, LEVEL AND GRID LINE MUST HAVE A SEPARATE LAYER.. THANKS Edited August 14, 2019 by Ish MODIFY COMMENTS Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 15, 2019 Share Posted August 15, 2019 (edited) 13 hours ago, Ish said: no sir , I dont want selection list . I thought this is for 1:1 and 1:5 ONLY, NOW 1 CHECK . THIS IS FOR ANY VERTICAL SCALE, GOOD. NO. 1 Too late I've already changed it. I suppose I'll have to change it back now. 13 hours ago, Ish said: whAT ABOUT FIX INTERVAL: (POINT NO 3.) AND CROSS SECTION Interval already sorted. Cross Section with centreline is still in production. 13 hours ago, Ish said: PLZ ADD A CODE FOR LAYER . OFFSET, LEVEL AND GRID LINE MUST HAVE A SEPARATE LAYER.. Layer Name and colour for each? I can't code what I don't know Can you standardise the datum level as just a number 30 instead of DAT:30 as this would make it easier to re-use code? I am also using the height of this text for rest of the text to be inserted in that section. And is it possible to make the centreline a line instead of a polyline as this requires less verticality checking? Edited August 15, 2019 by dlanorh clarity Quote Link to comment Share on other sites More sharing options...
Ish Posted August 15, 2019 Author Share Posted August 15, 2019 4 hours ago, dlanorh said: Interval already sorted. Cross Section with centreline is still in production. thanks sir, it means now i will type only one time and i will get value accordingly. good for cross section i will wait sir. no problem 4 hours ago, dlanorh said: Can you standardise the datum level as just a number 30 instead of DAT:30 as this would make it easier to re-use code? I am also using the height of this text for rest of the text to be inserted in that section. Yes, Sir you can use number 30 instead of DAT:30, i write it for more information. 4 hours ago, dlanorh said: And is it possible to make the centreline a line instead of a polyline as this requires less verticality checking? Yes. You can make the centreline a line instead of a polyline. 4 hours ago, dlanorh said: Layer Name and colour for each? I can't code what I don't know it will be something like this (setq clr (getvar 'clayer)) (cond ( (null (tblsearch "LAYER" "Coor Text")) (command "-layer" "_M" "Coor Text" "_C" 7 "" "")) (t (setvar 'clayer "Coor Text"))) thanks for good support. plz upload update ODL.LSP Quote Link to comment Share on other sites More sharing options...
dlanorh Posted August 15, 2019 Share Posted August 15, 2019 11 hours ago, Ish said: thanks sir, it means now i will type only one time and i will get value accordingly. good for cross section i will wait sir. no problem Yes, Sir you can use number 30 instead of DAT:30, i write it for more information. Yes. You can make the centreline a line instead of a polyline. it will be something like this (setq clr (getvar 'clayer)) (cond ( (null (tblsearch "LAYER" "Coor Text")) (command "-layer" "_M" "Coor Text" "_C" 7 "" "")) (t (setvar 'clayer "Coor Text"))) thanks for good support. plz upload update ODL.LSP Attached is unfinished, but working updated lisp (Option 1 only). Everything will now be put into layer "Coor Text". ODL.lsp 1 Quote Link to comment Share on other sites More sharing options...
