ktbjx Posted August 1, 2019 Share Posted August 1, 2019 (edited) (defun c:test(/ sel int ent str end hcol ss) (While T (setq ss (ssget "_:L" (list '(0 . "TEXT")))) (setq hcol (cdr (assoc 62 (Entget ss)))) (if (setq int -1 sel (ssget "_:S" '((0 . "LINE")))) (while (setq ent (ssname sel (setq int (1+ int)))) (setq str (cdr (assoc 10 (entget ent))) end (cdr (assoc 11 (entget ent))) ) (entmake (list '(0 . "CIRCLE") (cons 10 (mapcar '(lambda (q p) (* (+ q p) 0.5)) str end)) (cons 40 (/ (distance str end) 2.)) (cons 62 hcol) ) ) ) ) ) (princ) ) I am having trouble with my lousy coding, basically i need to get the color from TEXT and then use that color to the line and circle that im gonna be selecting i dont know whats wrong with this code here i added a sample file: sample.dwg my end result is hatch all the circles based from the text color but my question is just change circle color, because i have a routine that hatches all the circles based from the circle color Edited August 1, 2019 by ktbjx Quote Link to comment Share on other sites More sharing options...
rrulep Posted August 1, 2019 Share Posted August 1, 2019 1 hour ago, ktbjx said: (defun c:test (/ sel int ent str end hcol ss) (while t (setq ss (ssget "_:L" (list '(0 . "TEXT")))) (progn (setq idx 0) (repeat (sslength ss) (setq ent (ssname ss idx)) (setq hcol (cdr (assoc 62 (entget ent)))) (if (setq int -1 sel (ssget "_:S" '((0 . "LINE"))) ) ;_ end of setq (while (setq ent (ssname sel (setq int (1+ int)))) (setq str (cdr (assoc 10 (entget ent))) end (cdr (assoc 11 (entget ent))) ) ;_ end of setq (entmake (list '(0 . "CIRCLE") (cons 10 (mapcar '(lambda (q p) (* (+ q p) 0.5)) str end)) (cons 40 (/ (distance str end) 2.)) (cons 62 hcol) ) ;_ end of list ) ;_ end of entmake ) ;_ end of while ) ;_ end of if (setq idx (1+ idx)) ) ;_ end of repeat ) ;_ end of progn ) ;_ end of While (princ) ) ;_ end of defun ;|«Visual LISP© Format Options» (100 1 2 2 T "end of " 100 9 1 1 1 T T nil T) ;*** DO NOT add text below the comment! ***|; I am having trouble with my lousy coding, basically i need to get the color from TEXT and then use that color to the line and circle that im gonna be selecting i dont know whats wrong with this code here i added a sample file: sample.dwg 138.34 kB · 1 download my end result is hatch all the circles based from the text color but my question is just change circle color, because i have a routine that hatches all the circles based from the circle color Try This (defun c:test (/ sel int ent str end hcol ss) (while t (setq ss (ssget "_:L" (list '(0 . "TEXT")))) (progn (setq idx 0) (repeat (sslength ss) (setq ent (ssname ss idx)) (setq hcol (cdr (assoc 62 (entget ent)))) (if (setq int -1 sel (ssget "_:S" '((0 . "LINE"))) ) ;_ end of setq (while (setq ent (ssname sel (setq int (1+ int)))) (setq str (cdr (assoc 10 (entget ent))) end (cdr (assoc 11 (entget ent))) ) ;_ end of setq (entmake (list '(0 . "CIRCLE") (cons 10 (mapcar '(lambda (q p) (* (+ q p) 0.5)) str end)) (cons 40 (/ (distance str end) 2.)) (cons 62 hcol) ) ;_ end of list ) ;_ end of entmake ) ;_ end of while ) ;_ end of if (setq idx (1+ idx)) ) ;_ end of repeat ) ;_ end of progn ) ;_ end of While (princ) ) ;_ end of defun ;|«Visual LISP© Format Options» (100 1 2 2 T "end of " 100 9 1 1 1 T T nil T) ;*** DO NOT add text below the comment! ***|; 1 Quote Link to comment Share on other sites More sharing options...
ktbjx Posted August 1, 2019 Author Share Posted August 1, 2019 11 minutes ago, rrulep said: Try This (defun c:test (/ sel int ent str end hcol ss) (while t (setq ss (ssget "_:L" (list '(0 . "TEXT")))) (progn (setq idx 0) (repeat (sslength ss) (setq ent (ssname ss idx)) (setq hcol (cdr (assoc 62 (entget ent)))) (if (setq int -1 sel (ssget "_:S" '((0 . "LINE"))) ) ;_ end of setq (while (setq ent (ssname sel (setq int (1+ int)))) (setq str (cdr (assoc 10 (entget ent))) end (cdr (assoc 11 (entget ent))) ) ;_ end of setq (entmake (list '(0 . "CIRCLE") (cons 10 (mapcar '(lambda (q p) (* (+ q p) 0.5)) str end)) (cons 40 (/ (distance str end) 2.)) (cons 62 hcol) ) ;_ end of list ) ;_ end of entmake ) ;_ end of while ) ;_ end of if (setq idx (1+ idx)) ) ;_ end of repeat ) ;_ end of progn ) ;_ end of While (princ) ) ;_ end of defun ;|«Visual LISP© Format Options» (100 1 2 2 T "end of " 100 9 1 1 1 T T nil T) ;*** DO NOT add text below the comment! ***|; wow thanks so much! just what i need! Quote Link to comment Share on other sites More sharing options...
