NoroZorro Posted July 29, 2019 Share Posted July 29, 2019 Hello forum! i suspect that my dwg file is geo-referenced. However i fail to move or copy block at coordinates that I input. Please provide a step by step instructions. See file attached my first coordinate lat 45.56486111 long -73.58944444 Thank you geo_reference.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 30, 2019 Share Posted July 30, 2019 I don't think LT supports lat long input CIV3d does. You will need a conversion program to make new X&Y co-ordinates, there are some out there depends on where you are in the world also. 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 30, 2019 Share Posted July 30, 2019 I have moved your thread to the AutoCAD LT Forum. Quote Link to comment Share on other sites More sharing options...
steven-g Posted July 31, 2019 Share Posted July 31, 2019 Definately sounds more civil, but try this. 1 Quote Link to comment Share on other sites More sharing options...
eldon Posted July 31, 2019 Share Posted July 31, 2019 On 7/29/2019 at 8:41 PM, NoroZorro said: i suspect that my dwg file is geo-referenced..... I am not sure whether it is! It is certainly not to a UTM coordinate system. Using the geographic coordinate, one gets to 22e Av in Montreal. In Google Earth, changing to UTM coordinates, one gets (approximately) 610000e, 5046670n in zone 18T. Your drawing gives coordinates for the same spot as 297600e, 5047360n (approximately). So I reckon that Montreal has its own mapping grid. You should enquire at the city map makers if they have a conversion. 1 Quote Link to comment Share on other sites More sharing options...
TerryDotson Posted July 31, 2019 Share Posted July 31, 2019 Command: CGEOCS CGEOCS = "CANQ-M8" (read only) Your drawing appears to be of proper coordinates and having the proper system assigned. The lat/long you mention hit near the center of the street at coordinates of X=297817.960 Y=5047220.634. If you truly have AutoCAD LT, there is not much else you can do. 1 Quote Link to comment Share on other sites More sharing options...
NoroZorro Posted July 31, 2019 Author Share Posted July 31, 2019 3 hours ago, TerryDotson said: Command: CGEOCS CGEOCS = "CANQ-M8" (read only) Your drawing appears to be of proper coordinates and having the proper system assigned. The lat/long you mention hit near the center of the street at coordinates of X=297817.960 Y=5047220.634. If you truly have AutoCAD LT, there is not much else you can do. I mapped my coordinates on google earth. Then using a ruler on google earth, I placed my marks in Autocad Do you guys have a better solution for this task. Thanks Quote Link to comment Share on other sites More sharing options...
TerryDotson Posted July 31, 2019 Share Posted July 31, 2019 How did you get your drawing to Google Earth, I have to assume you have more than AutoCAD LT? It would really help everyone help you if we knew what software you have available. Quote Link to comment Share on other sites More sharing options...
NoroZorro Posted July 31, 2019 Author Share Posted July 31, 2019 Then using a ruler I placed my markers on dwg file. Not very accurate though Quote Link to comment Share on other sites More sharing options...
BIGAL Posted August 1, 2019 Share Posted August 1, 2019 Use Align pick furthest apart points on image, picking same point as the co-ordinates. This can rotate and scale image or plan. You need to look into georeferenced images, from Google maps or near map. These hold the corrected co-ordinates and scaling for the image, LT will still be a problem compared to autocad which has program solutions. Your welcome to re-engineer this into say excel. rescale image.lsp Quote Link to comment Share on other sites More sharing options...
