PaulMacAD89 Posted July 28, 2019 Share Posted July 28, 2019 I’ve been a technical kitchen designer for many years, using 2020 Design and Chief Architect. I just started working for a local Design Build that uses AutoCAD full version for all drawings for all trades. I have a background using AutoCAD from vocational training as well as a brief few years doing shop drawings for a millwork company. It’s hard for me to wrap my head around the fact I’m creating cabinets from lines ( floor plan view to elevations ) when I just think of how much time would be saved if using other software. The company has standards for different line types, layers on all the particular plans. They use blocks for the different door styles and drawer fronts appliances, plumbing fixtures etc. I respect it and they do a great job at what they do, but I feel that I could be doing things that aren’t so archaic to make the process quicker and easier from project to project. I’d really like to wow them with some ideas of things that you guys might do to make things easier. Maybe using dynamic blocks (not familiar with the limitations or the process) with different options for door swings? Can you show different line types in a single block? Maybe create a catalog of different size cabinets with different door/drawer configurations. I’m really just looking for ideas and inspiration on things you guys do in similar roles. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 29, 2019 Share Posted July 29, 2019 Steven-g has done a lot with cabinets he may answer, not my main stream, really automation is what it is all about, don't draw lines, draw doors panels etc You are right dynamic blocks are becoming more the norm and for cabinetry makes a lot of sense. Its about enter length width height number of doors and type all done including cut lists. Have a look in Showcase here and in Particular David Bethel. Are you aware of programming in lisp or VBA .net etc in Autocad. This is a simple example, next step would be the parts list. Quote Link to comment Share on other sites More sharing options...
steven-g Posted July 29, 2019 Share Posted July 29, 2019 Yes you can have different linetypes in a block/dynamic block. How are the blocks used by the company you are now working for, a block is usually used just to save on repeating work, so you would draw one door front then use that as a block to place all the cabinet doors then if the design changes slightly edit the block and all the doors that use that block are automatically updated. A dynamic block will allow you to easily use doors with different dimensions to stretch the width and height of the doors, the only drawback of that is that if sizes change then each individual door will need editing separately (unless the dimensions are the same). You can also use visibility states within a dynamic block to turn on/off various features, depending on the needs of a project, just watch out that things don't get too complicated. I find that a big library of simple (size adjustable dynamic blocks) is better than having a smaller library with feature adjustable objects. But that is personal choice and will depend on the workflow that a company uses, and also whether you need to cooperate with others on drawings, it is not much use spending a long time creating blocks that you can use if your collegues have to then work on the drawings and they have no idea how to use the blocks so they explode everything and edit the results manually. But that's all theory, if you could post examples of how things are done, it would be much easier to see how maybe the process could be improved (or not). As BIGAL says the big time saver is automation, so anything you learn with that in mind Lisp, VBA, etc would be of value. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted July 29, 2019 Share Posted July 29, 2019 At one point I worked for a cabinet maker who used Microvellum software. That will do what you want, but it's very expensive. For alternatives, look at WoodCAD or CabinetVision. Revit can produce 3D models, for less money, with models provided by many manufacturers. They use parametric design, which takes a little getting used to. If you stay with AutoCAD and use dynamic blocks, it will take some time to set up a useful system, but you get several advantages. You can always modify/update any part. You can tinker with your workflow until you have something that works for you. Just make sure you organize and document your library properly. Quote Link to comment Share on other sites More sharing options...
oddssatisfy Posted February 27 Share Posted February 27 (edited) On 7/29/2019 at 3:35 AM, PaulMacAD89 said: I’ve been a technical kitchen designer for many years, using 2020 Design and Chief Architect. I just started working for a local Design Build that uses AutoCAD full version for all drawings for all trades. I have a background using AutoCAD from vocational training as well as a brief few years doing shop drawings for a millwork company. It’s hard for me to wrap my head around the fact I’m creating cabinets from lines ( floor plan view to elevations ) when I just think of how much time would be saved if using other software. The company has standards for different line types, layers on all the particular plans. They use blocks for the different door styles and drawer fronts appliances, plumbing fixtures etc. I respect it and they do a great job at what they do, but I feel that I could be doing things that aren’t so archaic to make the process quicker and easier from project to project. I’d really like to wow them with some ideas of things that you guys might do to make things easier. Maybe using dynamic blocks (not familiar with the limitations or the process) with different options for door swings? Can you show different line types in a single block? Maybe create a catalog of different size cabinets with different door/drawer configurations of Kitchen Renewal Tacoma. I’m really just looking for ideas and inspiration on things you guys do in similar roles. I've been commissioned to build a set of kitchen cabinets that resemble freestanding furniture - FF, inset, painted and "legs" clipped at an angle- they will be a few inches thick. No kicks. Truly a freestanding look. Tops are granite - longest run is about 52" Although freestanding in appearance, they will be permanently placed. I'm struggling with how to secure the "legs." Independently or run the FF to the floor? Independently attached legs will be full thickness Hard Maple. If running the FF to the floor will be 7/8" stock with applied thickness underneath the box. If independently fastened, the bottom rail will leave a recessed area about 1" as the decks will be flush with the rail. Thought about a spacer in this area, then dowels all the way through the decks and into the legs. With the FF running to the floor, how about a cleat along the back wall for support? Ideas appreciated. I'm part-time commission work- no time constraints on this job. Edited February 27 by oddssatisfy Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 1 Share Posted March 1 Do you have an actual question? All you have done was to quote the previous thread. 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 1 Share Posted March 1 3 hours ago, SLW210 said: Do you have an actual question? All you have done was to quote the previous thread. Can I have a small bet with you that we'll never get an answer to that one? Or probably never see them post again? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 1 Share Posted March 1 1 hour ago, Steven P said: Can I have a small bet with you that we'll never get an answer to that one? Or probably never see them post again? My WAG is they will try to post a link to some non-cad website at some point in the future. 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted March 1 Share Posted March 1 Not this week though, maybe 6 months time? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 1 Share Posted March 1 Or even a year or 2. 1 Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted March 4 Share Posted March 4 On 3/1/2024 at 3:25 PM, SLW210 said: Or even a year or 2. This one took four and a half... Quote Link to comment Share on other sites More sharing options...
