Hi all,
I have some OLE images in around 350 drawings. I want all the ole objects to be deleted at once.
Right now I have a lisp, which doing good, but for that I have to open each single drawing and run that lisp on each drawing.
Thanks
Sumeet
Check out on www.lee-mac.com for his OBDC wrapper. May be useful does not open dwg's. There is also forgotten the command you can run Autocad as a background process using say a script like dlanorh suggested. Its runs as a command line-batch file process. Briscad has something as well I believe. this is an example.
rem batch file for accoreconsole.exe
cd\program files
cd autodesk
cd Autocad 2020
accoreconsole.exe /i d:\bigal\test.dwg /s d:\bigal\lisp\test.scr
[/code]
script
chprop
all
layer
0
close
N
Edited by BIGAL
