minejash Posted July 25, 2019 Posted July 25, 2019 hai, i need help.i have a working lisp routine which gives perpendicular line distance to main pline when clicked on a place perpendicular, all i want to add is the leader at the where i click and Easting and Northing and CH. and also instead of TEXT i need MText position where i can click. pls reply if its possible. i've added a screenshot for reference ..... thanks:) (defun c:Chi (/ s p c a d tp sch) (setq sch (getstring "\nSpecify start chainage : <0>")) ;"0" is set as the default value (if (= sch "")(setq sch "0")) (if (and (setq s (car (entsel "\nPick a polyline :"))) (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE") (alert "Invalid object! Please pick a polyline only.") ) ) (while (and (setq p (getpoint "\nSpecify point perpendicular to polyline :") ) (setq c (vlax-curve-getclosestpointto s p)) (setq a (angle p c)) (not (grdraw p c 1 -1)) ;; rubber line in red colour. (setq d (angle '(0. 0. 0.) (vlax-curve-getfirstderiv s (vlax-curve-getparamatpoint s c) ) ) ) (or (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4) (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4) ) (alert "Picked point is not a perpendicular to picked polyline. <!>" ) ) (setq tp (getpoint "\nSpecify Point for Text : ")) ) (entmakex (list '(0 . "text") '(100 . "AcDbEntity") '(67 . 0) '(370 . 13) '(100 . "AcDbText") (cons 10 tp) (cons 40 0.6) ; Change text height here (cons 1 (strcat "CH=" sch "+" (rtos (vlax-curve-getdistatpoint s c) 2 3) ;3 instead of 4 to specify precision ) ) (cons 71 0) (cons 72 0) (cons 11 '(0 0 0)) '(100 . "AcDbText") (cons 73 0) ) ) ) ) (princ) ) (vl-load-com) 1 Quote
Ish Posted July 25, 2019 Posted July 25, 2019 On 7/25/2019 at 9:21 AM, minejash said: hai, i need help.i have a working lisp routine which gives perpendicular line distance to main pline when clicked on a place perpendicular, all i want to add is the leader at the where i click and Easting and Northing and CH. and also instead of TEXT i need MText position where i can click. pls reply if its possible. i've added a screenshot for reference ..... thanks:) (defun c:Chi (/ s p c a d tp sch) (setq sch (getstring "\nSpecify start chainage : <0>")) ;"0" is set as the default value (if (= sch "")(setq sch "0")) (if (and (setq s (car (entsel "\nPick a polyline :"))) (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE") (alert "Invalid object! Please pick a polyline only.") ) ) (while (and (setq p (getpoint "\nSpecify point perpendicular to polyline :") ) (setq c (vlax-curve-getclosestpointto s p)) (setq a (angle p c)) (not (grdraw p c 1 -1)) ;; rubber line in red colour. (setq d (angle '(0. 0. 0.) (vlax-curve-getfirstderiv s (vlax-curve-getparamatpoint s c) ) ) ) (or (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4) (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4) ) (alert "Picked point is not a perpendicular to picked polyline. <!>" ) ) (setq tp (getpoint "\nSpecify Point for Text : ")) ) (entmakex (list '(0 . "text") '(100 . "AcDbEntity") '(67 . 0) '(370 . 13) '(100 . "AcDbText") (cons 10 tp) (cons 40 0.6) ; Change text height here (cons 1 (strcat "CH=" sch "+" (rtos (vlax-curve-getdistatpoint s c) 2 3) ;3 instead of 4 to specify precision ) ) (cons 71 0) (cons 72 0) (cons 11 '(0 0 0)) '(100 . "AcDbText") (cons 73 0) ) ) ) ) (princ) ) (vl-load-com) Expand may be you need offset text also. CH=:4+676.422 off=xx.xx E= N= Quote
BIGAL Posted July 26, 2019 Posted July 26, 2019 minejash if you google leader XY you will find the bit of missing code. Quote
minejash Posted July 27, 2019 Author Posted July 27, 2019 I don't know how to join the lisp codes, i wanted the cords with the existing changes i am getting, thats why. Please see the screen shots. thanks. Quote
BIGAL Posted July 27, 2019 Posted July 27, 2019 You will have to replace the entire entmakex " Text" section I would suggest as you are learning you would be better of using (command "leader" that is what I was suggesting, did you find any code when you googled ? As you get more experienced entmakex is a lot faster but requires more input and easier to get wrong. Quote
minejash Posted July 27, 2019 Author Posted July 27, 2019 @BIGALi got the coordinates lisp, but i got no idea about Lisp codes and how to modify it properly. that's the problem. ill share the coordinates with leader lisp here. don't know how to combine the 2 lisps together.. ;cord-ldr.lsp ; x,y Coordinates on Leader Lines (defun C:CR (/ PNT1 P1X P1Y STDY DY PTXT ) (setq PNT1 (getpoint "\nPick coordinate point: ")) (setq P1X (car pnt1)) ;x coord (setq P1Y (cadr pnt1)) ;y coord (setq STDX (rtos P1X 2 3)) (setq STDY (rtos P1Y 2 3)) ;(setq COORD (strcat "E=" STDX "\nN=" STDY)) (setq PTXT (getpoint "\nPick text location: ")) (command "leader" PNT1 PTXT "" (strcat "E=" STDX) (strcat "N=" STDY) "") (princ)) ; end Quote
minejash Posted July 28, 2019 Author Posted July 28, 2019 can anyone help please? ive tried and failed to write it..thanks Quote
