Lando0529 Posted July 23, 2019 Posted July 23, 2019 Hi all, I am an architecture student and I was wanting to know is it worth the time to learn Rhino for some of my school projects. I am well versed in Revit, Fusion 360, some Inventor and some Autocad. I find that I pick up new programs pretty easily but was wondering if any of the tools used in Rhino compare to those in other Autodesk software? Any info is appreciated! Thanks! Quote
f700es Posted July 23, 2019 Posted July 23, 2019 I used to play around with Rhino a bit and I found it very similar to AutoCAD. Have you downloaded the trial yet? If not do that and give it a go. To me I didn't see Rhino as a direct competitor to AutoCAD but more as a general nurbs 3D programs. Quote
ammobake Posted July 24, 2019 Posted July 24, 2019 I messed around with rhino back like 2006/2007. It's actually pretty cool for creating 3d visualizations. For our small design team working in R&D it was more like a supplement to AutoCAD and Solidworks. We mainly used Solidworks though for our 3D modeling and conceptual plans for our prototypes. Solidworks was perfect for us though especially building prototypes where parts would change all the time to fix some unexpected problem. We always had 1 assembly we would work on to represent the finished product. The only time we really used Rhino was for 3D visualizations and we would use those visualizations to get prints made on foam board for certain DOD conferences or events the company would attend. You can also use that same process but cut out those foam board components and construct a scale model that way. We did that a couple times too. Works pretty good. I think once I used Rhino to design a breakdown plan to show how one of these prototypes could be broken down to fit on a C-130 pallet. I had to make sure the total breakdown height was within certain tolerances and not over a certain height - so that it could fit into the aircraft while maintaining a certain clearance. ChriS Quote
f700es Posted July 24, 2019 Posted July 24, 2019 What exactly are you wanting to "do" with Rhino? Quote
Cad64 Posted July 24, 2019 Posted July 24, 2019 I was just doing a little research on this topic and came across an old thread at the Rhino forum that may be of interest. https://discourse.mcneel.com/t/does-anyone-use-rhino-as-their-primary-architectural-cad-application/1629 Quote
Lando0529 Posted July 25, 2019 Author Posted July 25, 2019 I think the main thing I would use Rhino for is designing models I can laser cut, CNC, or 3d print. I'm mainly interested in the design/modeling capabilities Rhino presents verses those in Revit or Autocad. I likely won't be using Rhino for construction drawings/details. Thanks for all of your replies! Quote
f700es Posted July 25, 2019 Posted July 25, 2019 OK before you buy Rhino take a look at MoI 3D. It is made buy a guy that used to work for Rhino and it is made for general 3d work. it is also very easy to learn and use as well as under $300 USD. MoI 3D Student price = $84.95 USD Quote
