Layer palette update
casariana
Hello everyone,
When I create a new layer using
(command "._Layer" "_Make" "layer_name" "_Color" "94" "layer_name" "_LT" "Continuous" "layer_name" "")
Even if I set the new layer as current with
(setvar "clayer" "layer_name")
Although the layer is created, It won't show at the layer palette, unless I close and reopen the drawing or insert an object at the layer.
The same happens when I use the Steal code from Lee Mac.
I also tried to thaw and turn the layer on using this code I adapted from some forum (sorry I didn't credit the code I based mine, but I cannot find it anymore):
(defun turn_on ( layer / dx en in ss )
  (vl-load-com)
   (if (not (null (setq en (tblobjname "LAYER" layer))))
       (if
           (and
               (setq en (entget en)
                     dx (assoc 70 en)
                     en (entmod (subst (cons 70 0) dx en))
               (setq ss (ssget "_X" (list (cons 8 layer))))
             (repeat (setq in (sslength ss))
               (entupd (ssname ss (setq in (1- in))))
       (vla-put-LayerOn (vlax-ename->vla-object (tblobjname "LAYER" layer)) 1)
Still, the layer created is not showing in the layer palette list. How could I fix it?
Thanks a lot!
You have sent me a PM which refers to this topic I think. The fact that you have received no answer does not means members have missed it. It may just be a problem that is hard, or impossible, to solve. IMO it is probably a bug in the layer palette list. I use BricsCAD and do not encounter this bug with, what I think is, the equivalent feature: the Layers panel.
Maybe there are commands to close and reopen the palette in AutoCAD that can be used to create a workaround?
Assuming you're using a Ribbon or Toolbar macro simply add CLAYER layer_name to the end instead of
The Ribbon display doesn't update to code as that would slow the code.
I just tested in AutoCAD 2019 and could not reproduce this? Do you have all service packs installed? What graphics card are you running?
Thank you very much for your answer and sorry to bother you, I got worried I messed it up! 😅
Anyway, I tried to do what you said and  it did not solve my problem, unfortunately.
But I am greatful for your reply!
Tombu, thank you for your reply but I am not using Ribbon or Toolbar. I was refering to the layer palette, the layer properties manager.
Hey ronjonp, thank you for your help! I use the student version, so I don't have all the service packs. I have a Intel HD Graphics 520. You say you could not reproduce it so the created layer was displayed at the layer palette? That's intriguing 🤔
Anyways, what kinda solved my question was to make a block with a matrix of points from all layers. Then I insert and erase the block after creating the layers. This way I garantee that an object of each layer is being inserted.
This doesn't please me, but works.
17 hours ago, tombu said:
Just guessing in your Layer Properties Manager is the Active Filter "All Used Layers"?
Change it to All.
Yes! That's it! I feel kind of stupid I didn't see that before.
Thank you very much!
It's always good to hear a puzzle has been solved.  Thanks for letting us know.
