Oscar Posted July 21, 2019 Share Posted July 21, 2019 Another CAD user on reddit/career advice suggested I learn AutoLISP to boost my speed in drawings (Engineers want more speed from me). I use a few default ones that my companies template provided but they are nothing special. It sounds that LISP can be powerful. Where do I start learning about them? Quote Link to comment Share on other sites More sharing options...
paulmcz Posted July 21, 2019 Share Posted July 21, 2019 (edited) Autolisp can make you a way faster. I once wrote a lisp for drawing development for sheet metal box that proved to be 150 times faster than doing it without the lisp. Start with Afralisp. Edited July 21, 2019 by paulmcz 1 Quote Link to comment Share on other sites More sharing options...
Oscar Posted July 21, 2019 Author Share Posted July 21, 2019 47 minutes ago, paulmcz said: Autolisp can make you a way faster. I once wrote a lisp for drawing development for sheet metal box that proved to be 150 times faster than doing it without the lisp. Start with Afralisp. thanks Paul Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 21, 2019 Share Posted July 21, 2019 Just look at something you draw all the time and have a think about it, have a look at this example for a 3d table. The docx has numerous lisp examples. Just appload "make furniture table" Multi GETVALS.lsp Make furniture table.lsp Lisp files march 2019-3.docx 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted July 22, 2019 Share Posted July 22, 2019 There is a lot at Autodesk, many are free or a couple $$. https://apps.autodesk.com/en Sometimes LISP can speed you up, it really depends on what you do. I still use a lot of the Express Tools, but for the most part, I do not use nearly as many as I did at some previous jobs. Quote Link to comment Share on other sites More sharing options...
Steven P Posted July 23, 2019 Share Posted July 23, 2019 Like BIgAl says, what do you do all the time that takes more than a simple command or mouse click? Start simple and work from there - and you will learn as you go This forum is great for advice and LISPs, often what I want has been asked before so there are ready made solutions. Another great resource is Lee Macs LISP website. I started with 'utilities' rather than automating my work itself. For example my first one was 'Zoom All' (command line command 'ZA') which only saved typing 6 characters but.. its still quicker. The other one I use all the time is a plotting lisp, 'plota3' and off it goes, A3 plot without the dialogue box (so long as the drawing is set up OK in the first place), saves time. Worth doing I can take these anywhere with me. After that I looked at my actual work and have a few that will automate tasks I do often. Often I will use a LISP for work more for consistency and accuracy rather than the speed boost itself (eliminating typing errors). The 'Zoom All' LISP might be a good start, if you can type the command into the command line you can make it into a LISP really easily. Just save as a new LISP name, and change the command and away you go: (defun c:za() ;define name of LISP, use c: to enable you to run it fromt he command line (command "zoom" "a") ;start with 'command' to tell it your runnign a command line LISP - and then between "" everything you type in and off you go ) ;end the LISP defnition 1 Quote Link to comment Share on other sites More sharing options...
hosyn Posted June 11, 2020 Share Posted June 11, 2020 On 7/22/2019 at 4:27 AM, BIGAL said: Just look at something you draw all the time and have a think about it, have a look at this example for a 3d table. The docx has numerous lisp examples. Just appload "make furniture table" Multi GETVALS.lsp 2.11 kB · 11 downloads Make furniture table.lsp 1.5 kB · 10 downloads Lisp files march 2019-3.docx 559.06 kB · 12 downloads Hello Mr BIGAL Your words are gem.i saw the file "Lisp files march 2019-3.docx" .where can we find the file lisp mentioned.?? Quote Link to comment Share on other sites More sharing options...
