Muhammad Sadiq Posted July 21, 2019 Posted July 21, 2019 Dear All, I have an serious issue regarding removing of above subjected files. Due to this issue my dwg files size exceeding up to 9MB. I have attached all screen shots of those file extensions size. Kindly help me thanks in advance. Quote
ReMark Posted July 22, 2019 Posted July 22, 2019 What have you done to reduce file size? Have you run the Overkill, -Purge Regapps, -Purge All, and Audit commands? Have you tried using the WBlock command? Quote
Muhammad Sadiq Posted July 22, 2019 Author Posted July 22, 2019 Yes, @ReMark I had tried all above commands. But finally I converted the dwg into DXF format and applied audit command then file reduced into the 347KB. Thanks a lot. Quote
