alec Posted July 17, 2019 Posted July 17, 2019 Hi, I've started using Draftsight 2019. I use the line type Batting as a construction industry standard for cavity wall insulation. I can change the line scale to fill the space but when I go to the layout the scale is wrong and it shows as a massively wide linetype. In AutoCAD I could go to PSLTSCALE and change to 1, then regen all and all would be well. I cant find a command in Draftsight that does the same though. Can anyone help? Its driving me bleeding nuts! Quote
