I need a little help redefining the explode command. I am tired of users exploding dimensions, multileaders, Civil 3D objects and so on. I want to redefine explode so that the only objects that can be exploded are blocks and polylines. I managed to get it working, but it only selects one object. When I select more than one object it only explodes the last object selected.
How do I make the lisp explode multiple polylines or blocks?
(command "UNDEFINE" "EXPLODE")
;undefine the Explode command
(setq echo (getvar "cmdecho"))
(setvar "cmdecho" 0)
(defun C:EXPLODE (/ blpl echo)
(alert "\nYou are ONLY allowed to explode blocks or polylines\n\nContact CAD Manager if you have questions")
;inform the user
(prompt "\nSelect a Block or Polyline: ")
(setq blpl (ssget '((-4 . "<OR")(0 . "INSERT")(0 . "LWPOLYLINE")(-4 . "OR>"))))
(command ".EXPLODE" blpl)
;explode the object
;finish clean
);defun
(setvar "cmdecho" echo)
;restore cmdecho
I think you need to set the sysvar "QAFLAGS" to 1 to allow explode to work on a selection set.
(setvar "QAFLAGS" 1)
(command ".EXPLODE" blpl "")
(setvar "QAFLAGS" 0)
NOTE : You have to insert a "" at the end of the command for it to work properly.
You also need to set it back immediately you've finished as, IIRC, it is an undocumented variable and could have unforseen consequences with other commands.
Edited by dlanorh
Updated code
;inform the user
;explode the object
;finish clean
);defun
;restore cmdecho
You're generous .. I wouldn't let them explode my blocks! :)
