Mohsen.Amiri Posted July 15, 2019 Posted July 15, 2019 Hello I have so many numbers in a AutoCAD file. So I want to find and select the numbers only smaller that an special value. How can I do it? Quote
rkmcswain Posted July 15, 2019 Posted July 15, 2019 (edited) Do you mean that you have TEXT objects that contain numeric values? For example, you have a TEXT object that is "2" and another one that is "14" and another one that is "428", and you want to find all of the TEXT objects that contain a numeric value less than 100 (which would be the "2" and the "14")? If so, see this. Edited July 15, 2019 by rkmcswain add URL Quote
Mohsen.Amiri Posted July 16, 2019 Author Posted July 16, 2019 (edited) Hi I have so many numbers as TEXT in AutoCAD file. Now I want to select the numbers only between two values (minimum value<numbers<maximum value). How an I do it? Filter command can not do it, because it identifies numbers as 'Text value', not Number and then it can not assign "<" and ">" to it. Have a look at photo attached. What is your idea? Thank you very much. Edited July 16, 2019 by Mohsen.Amiri Quote
SLW210 Posted July 16, 2019 Posted July 16, 2019 I merged your posts. Please only post one thread for the same inquiry. Quote
dlanorh Posted July 16, 2019 Posted July 16, 2019 @Mohsen.Amiri What do you want to do with the "text" numbers once you've selected them? Quote
rkmcswain Posted July 16, 2019 Posted July 16, 2019 8 hours ago, Mohsen.Amiri said: What is your idea? Did you see the lisp file in the link I posted? Quote
