zwonko Posted September 22, 2021 Posted September 22, 2021 (edited) Give sample dwg, mark what You need. Also write od You want to set section number manualny od it should be increment. Maybe just LeeMac NumInc lsp is what You need. Edited September 22, 2021 by zwonko Quote
AirBall Posted January 18, 2023 Posted January 18, 2023 I modified a litle bit a LISP long_section_3dp and a result is first section in example.dwg. Can anyone help me to modified a lisp to look similar like the second section in dwg (to add vertical scale bar, scale and number of point and distance between). example.dwgFetching info... long_section_3dp - modified.lspFetching info... Quote
Guest Posted January 18, 2023 Posted January 18, 2023 Hi, I use block attribute for the points. Is it possible to include in the update to read the numbers of the attributes and insert them to the long section ? example.dwgFetching info... Quote
AirBall Posted September 18, 2024 Posted September 18, 2024 Hello, Does anybody know how to set default value for horizontal and vertical scale 100 , and starting chainage 0 in previous LIPS long_section_3dp. But I want to keep option to enter scale. (setq h_s (getint "\nEnter horizontal scale :")) (setq v_s (getint "\nEnter vertical scale :")) (setq tex1 (getreal "\nEnter starting chainage :")) Quote
aridzv Posted December 21, 2024 Posted December 21, 2024 a litle late... (if (not(setq h_s (getint "\nEnter Horizontal Scale<100> :"))) (setq h_s 100)) (if (not(setq v_s (getint "\nEnter Vertical Scale<100> :"))) (setq v_s 100)) (if (not(setq tex1 (getreal "\nEnter Starting Distance<0> :"))) (setq tex1 0)) Quote
